Author Topic: Petrol Smell  (Read 2715 times)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
Petrol Smell
« on: 30 March 2010, 13:50:28 »
Hi all,
For a while now, I've been getting a very slight petrol smell when I come to a stop, and the engine is just idling. Nothing at all when the car is in motion, just when you come to a stop, even if there are no cars around. Does not seem to be any difference if the blowers are on high or low. Have checked obvious places around fuel pipes etc. and no sign of leakage, no drip marks under the car, seems to happen less on a longer run. Any suggestions? V6 2.6 - Cheers  :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
mathewst
  • Split, Croatia
    • v40
Re: Petrol Smell
« Reply #1 on: 30 March 2010, 13:58:03 »
If blowers on and off make no difference, I would sniff a little around top of the tank (fuel pump).
Re: Petrol Smell
« Reply #2 on: 30 March 2010, 13:58:04 »
Remove the tank sender inspection cover from the boot floor and have a look at the pipes on the tank top plate.
Rockhampton
  • Trecelyn, Gwent
  • Gone!
Re: Petrol Smell
« Reply #3 on: 30 March 2010, 17:00:13 »
Cheers, both - I'll take a look when the rain stops!  :)
Re: Petrol Smell
« Reply #4 on: 30 March 2010, 17:12:21 »
Check that the fuel filter isn't leaking  :y
Kiksomass
  • Northampton
  • Its all about the bass!
Re: Petrol Smell
« Reply #5 on: 30 March 2010, 17:23:36 »
Had the same on a Vectra once.Did my nut in for ages and eventually I sourced it to the filler cap.While the fuel is still sloshing about after a run,stop the car and have a sniff around. I wasn't 100% but replaced the cap for a new one anyway and solved the problem instantly :y
Growing old is inevitable....growing up is OPTIONAL!
Rockhampton
  • Trecelyn, Gwent
  • Gone!
Re: Petrol Smell
« Reply #6 on: 30 March 2010, 20:30:51 »
Cheers - that's worth a try too.....
Fuel filter was replaced a couple of months ago, so I guess it's worth a check.... don't want to waste any petrol, the price it is right now!!! :y
Rockhampton
  • Trecelyn, Gwent
  • Gone!
Re: Petrol Smell
« Reply #7 on: 17 April 2010, 20:53:29 »
Sorted this now - noticed that the rubber seal between the filler neck and bodywork had perished - Managed to obtain a replacement from the Dark Side (thanks DLK  :y) and the smell has gone.  :y
unlucky mark mv6
  • tipton,west mids
Re: Petrol Smell
« Reply #8 on: 17 April 2010, 20:58:12 »
Had the same with my 2.2 vec aswell mate,rubber seal on the cap. :y
Re: Petrol Smell
« Reply #9 on: 17 April 2010, 21:04:50 »
Good to see you got it sorted  :y
