Author Topic: Tyre Pressures  (Read 2767 times)
Missy_MV6
Tyre Pressures
« on: 17 April 2010, 14:59:35 »
Heres an easy one for you guys..What should be the correct tyre pressures on a normal load for a facelift MV6 3litre :y
Angie xx
Re: Tyre Pressures
« Reply #1 on: 17 April 2010, 15:00:28 »
31 on the front, 33 on the rear ;) ;)
Missy_MV6
Re: Tyre Pressures
« Reply #2 on: 17 April 2010, 15:17:14 »
Thanks  :y ;)
Angie x
Re: Tyre Pressures
« Reply #3 on: 17 April 2010, 19:55:34 »
Page 227
http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf
my handbook for the earlier car actually says 31.5 psi for both front & rear .... but what a psi between friends  :y
KW
Re: Tyre Pressures
« Reply #4 on: 17 April 2010, 20:00:50 »
Personally can't remember our MIG now, but the tyre pressures should be located somewhere within the car.
Normally on the door jam, but sometimes under the bonnet.
Failing that, the Owners handbook (easily found via Google) will tell you what's what.
I know violence isn't the answer, I got it wrong on purpose.
Re: Tyre Pressures
« Reply #5 on: 17 April 2010, 20:07:18 »
or clicking the link above in my post!  :-?
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
Re: Tyre Pressures
« Reply #6 on: 17 April 2010, 20:53:15 »
if you want extra comfort drop the pressures 2 psi each..
ps if you wont hammer it..
« Last Edit: 17 April 2010, 20:53:44 by cem_devecioglu »
Re: Tyre Pressures
« Reply #7 on: 17 April 2010, 21:00:04 »
Page 227
The only thing Andy is we are talking of a 2000 3.0 V6, not a 3.2, and in my Vx manual for that model the pressure for three people is 31 (alright maybe 31.5 to be exact :D :D ;)) front and rear 33. ;) ;)
Re: Tyre Pressures
« Reply #8 on: 17 April 2010, 21:04:35 »
Page 227
My manual TS 1433-B-98 pg 204 shows 31.5 for front and rear on a saloon .....  :-/
Re: Tyre Pressures
« Reply #9 on: 17 April 2010, 21:32:21 »
imho those pressure settings are not best for every weather.. in cold and wet for example you can increase for better braking..  but if you are after comfort and can sacrifice some grip drop the pressure.. and craaaash bum bang ;D
Re: Tyre Pressures
« Reply #10 on: 18 April 2010, 00:51:18 »
33 to 34 on my conti sc3s, higher than usual, but below 30 they go squidgy and wonder around, keeps em in the right zone longer as they naturally leek down.
Re: Tyre Pressures
« Reply #11 on: 18 April 2010, 00:56:37 »
Do you find you get horrendous centre wear on the rears? Mine are down at 31 and the rears are down to the limit at the centre  with plenty of tread to the edges as if they're overinflated.
MickAP
  • South Derbyshire
Re: Tyre Pressures
« Reply #12 on: 18 April 2010, 01:02:47 »
32psi on the estate, all round.
Tyre wear even across the tread front and back :y
Mick
« Last Edit: 18 April 2010, 01:03:20 by MickAP »
Re: Tyre Pressures
« Reply #13 on: 18 April 2010, 01:15:22 »
not that i've noticed, but drivers rear is only about 3k old due to a puncture on the previous one, and the pass side rear has a very slow leak so hard to tell what pressure its been runming on, i keep finding it at 28 to 27 after a week or so.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Tyre Pressures
« Reply #14 on: 18 April 2010, 01:20:08 »
34psi all round.
I am running lower profile tyres than standard (215-45-16).
To be completely honest, I always over-inflate by 2psi on any car.  Invariably there is 'some' loss over the time it takes to check again.
If only I had the time to check my tyre pressures once a week  ::)
