Author Topic: cutting out again  (Read 2028 times)
GLENNY BOY
  • dartford
    • cd 2.6 auto v6 2002
cutting out again
« on: 17 April 2010, 20:21:42 »
hi all need some advise please car keeps cutting out, today i drove for 5mins come to roundabout and it cut out  it wouldnt restart had to get a jump start from nice man in a van i dont understand why this happends checked clean  battery term, checked earth strap i have no battery light on dash when driving so i know its not alternator it doesnt do this all the time some times theres charge in the battery to restart if it cuts out , theres enough fuel any ideas  >:(
« Last Edit: 17 April 2010, 20:31:47 by PAMFLETT »
Re: cutting out again
« Reply #1 on: 17 April 2010, 20:39:07 »
Something seems to be draining the battery, and although you state it is not the alternator, it really does sound as though it could be.  Power is draining away whilst you are driving, and if the alternator is functioning correctly that should not happen.  The only time draining power happened to me, with the engine cutting out, was when my alternator packed up.
Does the radio die before the car comes to a halt?
« Last Edit: 17 April 2010, 21:06:04 by Lizzie_Zoom »
« Reply #2 on: 17 April 2010, 20:41:44 »
Same here  :y
« Reply #3 on: 17 April 2010, 20:42:17 »
Not necessarily true. Have you checked the alt. output http://www.omegaowners.com/forum/YaBB.pl?num=1225724099
With the Omega strange things are known to manifest themselves if you have a dodgy alternator  :-?
« Last Edit: 17 April 2010, 20:43:43 by RobG »
« Reply #4 on: 17 April 2010, 21:06:17 »
.................in addition always allow for the possibility that the alternator warning bulb has blown / been removed and may not show! ::) ::) ;)
GLENNY BOY
  • dartford
« Reply #5 on: 17 April 2010, 21:09:31 »
radio is on before car cuts out sometimes i lose radio and have to enter radio code when restarting and other times its okay :)
« Reply #6 on: 17 April 2010, 22:19:30 »
Yep a classic sign of losing electrical power from alternator, with the battery drained right out, so no means of running radio.  It just dies, as will all electrical equipment! ;)
PS In the 'old days; we always checked the drive belt tightness on the generator / alternator to ensure there was no 'slippage' thus reducing the power going into the engine / battery.  Worth a check? ;)
« Last Edit: 17 April 2010, 22:22:46 by Lizzie_Zoom »
hoofing it
« Reply #7 on: 17 April 2010, 22:24:33 »
start it then take the positive wire off the battery breifly if it stops alternator dead :y
GLENNY BOY
  • dartford
« Reply #8 on: 18 April 2010, 12:56:43 »
found out why its cutting out yes battery is knackered also the cutting out is the idle air control valve is sticking when you remove the black plug/clip car still should be running buts its not i adjusted the revs pulled plug/clip off and it was still running so ive been told the idle air valve so i think there about £40 of ebay i think anybody know anywhere were they are cheap apart from ebay :y
« Reply #9 on: 18 April 2010, 14:50:07 »
Glad you found the answer to, by the sounds of it two problems! 8-) 8-) 8-) 8-)
« Reply #10 on: 18 April 2010, 16:36:14 »
Check out the maintenance guides.
Remove and clean all the breathers, throttle body and idle valve....no need to replace anything other than a few gaskets.
Matchless
  • Nottingham
    • A white van
« Reply #11 on: 18 April 2010, 20:42:36 »
What do you mean when you said you adjusted the revs? Have you been playing with the throttle stop screw??
« Reply #12 on: 18 April 2010, 20:45:25 »
That takes me back to those fun days adjusting carburetors!! :D :D
I feel really at home now! :D :D 8-) 8-)
GLENNY BOY
  • dartford
« Reply #13 on: 18 April 2010, 21:40:15 »
no a friend of mine who used to work for vauxhall did not me never i wouldnt know were to look  ;D ;D ;D
« Last Edit: 18 April 2010, 21:41:55 by PAMFLETT »
Matchless
  • Nottingham
    • A white van
« Reply #14 on: 18 April 2010, 21:49:03 »
Throttle stop screw should not be adjusted....ever....even by someone who used to work for Vauxhall.
The throttle has to close completely so that all the idle air passes through the idle control valve.
To re-set this you have to remove the throttle body, clean the throttle disk thoroughly then set the screw so that the throttle shuts completely without sticking in the bore.
Re assemble then fix the original problem which was probably a gummed-up idle control valve due to blocked breather system.
Page created in 0.032 seconds with 17 queries.
