Author Topic: X30XE Engine Cutting Out / Refusing to Start  (Read 2062 times)
Elsheepo
  • Swindon, UK
« on: 19 April 2010, 15:35:32 »
Hi all,
Have only got the Omega back on the road recently, well only at the weekend actually.  Aside from a flat battery (the car was sat SORN’ed for just over a year) which I think has caused my airbag light to come on and need resetting, everything has been fine.  It has been starting fine, idling fine and driving like a dream until today; heading down the dual carriageway and the engine management and battery lights come on and she stops, freewheeling to safety thanks to having a lay-by within distance.  Battery is fine (its brand new) and the car turns over but did not want to restart, after about 30 minutes being left it did start but then duly cut out again.
RAC come out and tow the car home, they are unable to use their diagnostic equipment as it didn’t want to connect, however, based on my limited knowledge and the opinion of the patrolman it sounds like the crank sensor?
I have done a paper clip test and it does indeed throw out a code ’19’ which would further confirm the crank sensor but it also has a few other codes, here’s the sequence of codes ignoring ‘12’:
19
49
48
73
Can anyone offer some help; could it be that some of these codes are from old problems or would they automatically reset?  Does it still seem likely to be the crank sensor only or something else?  Incidentally, I performed the paper clip test both with the engine running and just the ignition circuit live.
Help!
« Last Edit: 19 April 2010, 15:36:50 by mikesouthby »
Check out my blog - http://www.mikesouthby.co.uk
Re: X30XE Engine Cutting Out / Refusing to Start
« Reply #1 on: 19 April 2010, 15:39:18 »
Change the crank sensor. 48 & 49 are telling you battery charge is low
« Reply #2 on: 19 April 2010, 15:42:20 »
starting & cutting out .... sounds like classic crank sensor failure to me too,  :y
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« Reply #3 on: 19 April 2010, 15:51:13 »
Ditto!
scream if you want to go faster!!!
« Reply #4 on: 19 April 2010, 15:51:32 »
Hi all,
19
49
48
73
Help!
Your diagnosis of a crank sensor is bang on!
The dealer will try to sell you wrong sensor, all 3.0l and 2.6/3.2 take the same, cheaper sensor.
« Reply #5 on: 19 April 2010, 16:04:44 »
Rather a generalised comment Jamie!  ::)  ::)
Omega Part Number Retail Price Normal Trade Trade Club
Crankshaft sensors
2.0 16v to 14194716                                90458251 £60.50 £54.46 £47.10
U25TD/X25TD                                  90487810 £98.50 £88.65 £76.94
2.5 (early models)                                 90492006 £83.50 £75.15 £65.12
2.5 (later models)                                 90492061 £61.50 £55.36 £47.88
2.0 8v                                   90493864 £60.50 £54.46 £47.10
2.0DTi/2.2DTi                                  90540188 £37.75 £33.98 £29.40
2.6/3.0/3.2                                  90540743 £55.00 £49.56 £42.63
2.0 16v from 14194717/31000001                              9174621 £36.60 £33.00 £28.47
Elsheepo
  • Swindon, UK
« Reply #6 on: 19 April 2010, 16:05:43 »
Thanks all, is the '73' code anything to worry about or is it related?
Does anyone have a part number and/or cost for the replacement, local Vx dealer with the VRM is quoted around £95+VAT...
Thanks again.
« Reply #7 on: 19 April 2010, 16:06:09 »
Crankshaft sensors
Its an inconsistency in EPC when using the registration/vin filters, throws up the wrong part ;)
Elsheepo
  • Swindon, UK
« Reply #8 on: 19 April 2010, 16:08:40 »
Excellent, thats really useful to know.  Much prefer the price too...
« Reply #9 on: 19 April 2010, 16:08:49 »
Hope it's right for 1600 Astras, I've just bought a crank sensor for a mate's car using the registration number  :-?  ;D
« Reply #10 on: 19 April 2010, 16:09:40 »
....  Much prefer the price too...
don't forget that the prices shown are plus vat  :y  :y
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #11 on: 19 April 2010, 17:50:27 »
Hi
It depends on the year of 3L, mine uses the 90492006 crank sensor, so not all 3L use the cheap one (wish mine did!)
Alan
PS Unless a past owner has fitted the wrong one and as it worked I've perpetuated the error!!
Crankshaft sensors
« Last Edit: 19 April 2010, 17:53:04 by alank46 »
