Author Topic: Question for Tunnie or Kevin Wood  (Read 1911 times)
« on: 19 April 2010, 14:19:27 »
Hi Guys, can you tell me what length your LPG tank was please? Many Thanks, Phil. :y
« Last Edit: 19 April 2010, 14:26:28 by philrich1064 »
Re: Question for Tunnie or Kevin Wood
« Reply #1 on: 19 April 2010, 16:14:40 »
Mine is an 80 litre, 360mm diameter by 892mm long.
Some dimensions of the various sizes here: http://www.stako.pl
I believe Tunnie went for a 90L which is 360x996.
Lazydocker has a 90L 400x847 IIRC.
Just a few of the sizes that are a "known fit" into a  saloon boot.
« Reply #2 on: 19 April 2010, 16:46:16 »
LDs I think is a tight squeeze to fit without removing bose amp to get tank in...
« Reply #3 on: 19 April 2010, 17:24:13 »
*gets tape measure, back in 5
« Reply #4 on: 19 April 2010, 17:32:55 »
Stako 90L Torpedo in mine, i'd say 97cm long, 39cm high, it just fits...
« Reply #5 on: 19 April 2010, 18:18:20 »
It is indeed... But possible with patience :y :y
« Reply #6 on: 19 April 2010, 18:54:32 »
Did indeed, mine is the 'long and thin' 90L
LD's is 'short & fat' version which is higher, guess there is a slight benefit with longer ones as it does give you a little of space above the tank. Enough for a couple of popup disc shape tents
« Reply #7 on: 19 April 2010, 19:10:21 »
Downside being the large amount of wasted space between the seats and the tank, whereas mine sits almost against the seats
« Reply #8 on: 19 April 2010, 19:38:06 »
I thought Tunnie's looked a little further back. Didn't fit between the shock absorber turrets, I guess?
« Reply #9 on: 19 April 2010, 20:10:32 »
No not quite, still little bit of space although not much. TBH i don't mind that gap its perfect for things like an umbrella, blanket, winter gear and such, and its hidden from sight
« Reply #10 on: 19 April 2010, 20:58:03 »
I did offer to make it fit... ... "Sammy!" ::) ::)
It took a little gentle persuasion to get it where it is TBH ;)
Martin_1962
« Reply #11 on: 19 April 2010, 20:59:53 »
Plenty of room for an amp and lots of Autoglym products
« Reply #12 on: 19 April 2010, 21:12:38 »
Thank you all very much fella's, it is much appreciated! :y Now I just need Teilo to reply to any of my calls & e-mails & I may be in business! :-/ :y Kind regards, Phil
« Reply #13 on: 19 April 2010, 21:49:57 »
Must confess... I didn't get a chance to chase him up for you last week :-[ :-[
I'm planning to have a yarn with him tomorrow (hopefully) so I'll see what I can do :y
« Reply #14 on: 19 April 2010, 21:55:52 »
Thats kind of you Paul, thanks mate  :y
