Author Topic: Misfire on a 2.5CD  (Read 825 times)
TR
Misfire on a 2.5CD
« on: 19 April 2010, 20:00:09 »
Hi there. A request if spmebody could help me out with a problem on a 2000 post facelift 2.5CD Estate. I've had the car from new and its done 120K. In the past 18 months I've had rocker gaskets and oil heat exchanger replaced by a dealer for £800 but recently engine has started to run rough.  It sounds as if it is  only running on 5 cylinders. I'm based in Leatherhead Surrey so would really appreciate it if someone could help me out or recommend a good garage in the area
Re: Misfire on a 2.5CD
« Reply #1 on: 19 April 2010, 20:13:08 »
welcome, firstly pop out the plug leads and check for any fluid in the wells.  :y
TR
« Reply #2 on: 19 April 2010, 21:13:50 »
Thanks have done this for the plug leads on the drivers side and no fluid here but cant get at those on the passenger side so easily. Will try again tomorrow when it is light
TR
« Reply #3 on: 20 April 2010, 19:33:53 »
Hi  many thanks for the advice  but think I've probably hit my limit in trying to get at the points on the passenger side. I don't want to remove things I might not be able to put back so looks like its a trip to the local garage. If there is fluid in the wells what is the prognosis minor or serious.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 20 April 2010, 20:27:45 »
The garage you have taken your car too mate seems well to expensive  :o
I have sent you a PM :y
