Author Topic: HBV leak  (Read 2007 times)
Agemo
  • Cleethorpes
  • Insignia
HBV leak
« on: 20 April 2010, 09:37:06 »
I have a slight weep from the bottom of the Heater By-pass Valve, Mine is the TD though, and the HBV looks different to the petrol ones. It is also fitted to a bracket & I can't see how it can be removed.
Anyone changed one on the TD?
Re: HBV leak
« Reply #1 on: 20 April 2010, 15:43:22 »
hbv is same accross the range last i heard, just lift it off its post.
Agemo
  • Cleethorpes
  • Insignia
Re: HBV leak
« Reply #2 on: 20 April 2010, 16:08:31 »
Thanks Chris, BUT, just been to the Stealers, there are TWO, the TD used one with 2 outlets, all Petrol models have 3 outlets. Mine is less than £30 with VAT, which is nice, but they are not in stock,  but I will have to get it off the bracket first.  ::)
Richard A
  • Aldridge, West Midlands
Re: HBV leak
« Reply #3 on: 20 April 2010, 18:42:03 »
Just fitted HBV part no V0090566947, it has two tubes on one side and one tube on the other, plus the vacuum tube on top.
It was the same on the diesel I had some years ago.
good luck
richard a
richard a
Agemo
  • Cleethorpes
  • Insignia
Re: HBV leak
« Reply #4 on: 20 April 2010, 19:06:49 »
Thanks Richard, but mine only has two ports, perhaps they changed them for the facelift.   ::)
charlie
  • sunderland
Re: HBV leak
« Reply #5 on: 20 April 2010, 21:02:52 »
Ive changed mine on my td it was an three outlet one,iirc the part no started with an 1.I first got a two outlet one which was wrong.But as for changing it,soooooooooo easy on a td ;D ;D ;D ;D ;D ;D
Agemo
  • Cleethorpes
  • Insignia
Re: HBV leak
« Reply #6 on: 20 April 2010, 21:15:06 »
OK Charlie, thanks, wish mine was the three port one. I agree it's so easy to get to on the Turbo Weasel, just won't come away from the bracket.
Edit:-  OK, got it free from the bracket, replaced it with a three port one with the bottom one blanked off. I will fit the right one as soon as I get one, but everything working fine, including cooling & heater.
Just so you will believe me that there are two:-
« Last Edit: 21 April 2010, 21:06:51 by Agemo »
