Author Topic: Wishbones and rear coil springs  (Read 1304 times)
DaveBrunel
  • Maidenhead, Berkshire
« on: 20 April 2010, 13:11:56 »
Hi Guys, please help answer a couple of questions;
I've found wishbones on ebay for as little as £33.90 a pair - can anyone advise if they've bought from this type of seller and if the wishbones have been good quality?
I'm aware of the need for tracking etc once fitted.
Both rear coil springs broken. My Elite looks like it had self-levelling at some point in the past, but now it just has standard shocks.
Any advice on where to get the springs from, and what type to specify to ensure I get the correct ones?
All help much appreciated :y
« Last Edit: 20 April 2010, 14:35:36 by splagflaf »
Re: Wishbones and rear coil springs
« Reply #1 on: 20 April 2010, 15:37:37 »
Hi Dave and welcome,
There are several sellers from various parts of tinternet, some are are worth fitting some not, trouble is there seems to be very little in the way of manufacturers markings to distinguish good from bad wishbones.
Known bad sellers are buypartsbuy for wishbones, going by other members posts, although others items seem reliable, and first line, avoid like the plague for all except filters it seems, certainly in my experience anyway.
The only reliable supplier that we can bolt a cast iron thumbs up to are Lemforder, they make and supply the originals to gm along with numerous other bushed chassis components, although these are in the order of £110 delivered from autovaux they are considerably cheeper than 235 a side from vx for the same part less a gm sticker.
When fitted be sure to tighten the bolts wheels loaded to avoid early failure. But when choosing supplier, also consider the cost of more likely early failure when fitting cheeper parts, your back to square one of they fail, possibly costing a pair of front tyres in ware, remove and fefit another set of wishbones and set up again. Could be a pricey pair of cheep wishbones. Having said that, plenty here have fitted cheeper wb's, just none know tha makers name.
Self level springs, kyb from most factors do the job nicely for 80 to 90 a pair, the sl shocks are only availabe from vx for 150 a pair on trade club, or just fit stock springs to go with the stock shocks, depends if you need or want the levelling option.
Shout if you need any vx parts on trade club as i have a card, or follow the abs link at the bottom of my post for the tc card.
hth
2woody
  • Northumberland
« Reply #2 on: 20 April 2010, 16:30:26 »
sound advice given above.
you could always retro-fit GM bushes into your own wishbones - that's what I'd go for. It's a little more expensive and more hassle, but the best way to get long-lasting replacements.
Don't go for aftermarket ones ( apart, perhaps, form Lemforder )
there were two kinds of rear spring, one designed for self-levelling and one not. Decide if you're going to go for self-levelling first and then fit the springs to suit.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #3 on: 20 April 2010, 20:28:14 »
What sort of job is it to fit new rear springs to a 2.6 V6 difficult, easy?
« Reply #4 on: 20 April 2010, 22:59:40 »
guide in maintenance section, involves dropping the dif, which sounds drastic, but it really is not hard. Need car on axle stands and lower the dif on a jack. May need to unhook exhaust to allow full clearance to get the spring out, but be carefull doing this if your exhaust is rusty behind the back box, might brake.
