Author Topic: temp gauge sensor location  (Read 1905 times)
Smooth
  • N.Ireland
« on: 25 April 2010, 11:21:49 »
Where is the temp gauge sensor on the 01 2.6,had plenum an all off recently and since rebuild its not working,had quick look round but cudnt see owt,any pics would be great,cheers all :y
If Jesus had a licence he would drive an MV6
ScottieMV6
  • Swinton, Manchester
Re: temp gauge sensor location
« Reply #1 on: 25 April 2010, 18:08:28 »
If its the same as the 3.0 V6 then its attached to the coolant bridge at the back of the V. Plenum and all inlet off and you will see it (or at least where it should be) :y
I'd rather be scared to death than bored to death!!
« Reply #2 on: 25 April 2010, 18:30:23 »
Can get to with scuttle off, but easier to see with plenum off.  Then its just behind the intake manifolds, in middle of coolant bridge.  Its a single spade type connector that clips onto sensor.
Smooth
  • N.Ireland
« Reply #3 on: 25 April 2010, 19:00:08 »
Thanks gentlemen   :y
« Reply #4 on: 25 April 2010, 19:40:11 »
Like I said, in the middle of the V ... at the back  ;)  ;)  ;)
