Author Topic: using water!!!!!!!!!!!!!  (Read 1539 times)
jayten10
« on: 25 April 2010, 13:48:48 »
hi all,
ive noticed that l am having to top up the coolant quite a lot in the space of a wek the warning sign has come on twice and when l open the tank it is almost empty.
there dosent appear to be any visual leaks nothing from underneath it dosent appear to be overheating it stays between 80-90 it is starting to worry me :'(
any help much appreciated cheers :)
amba
  • Medway towns
    • German V6
Re: using water!!!!!!!!!!!!!
« Reply #1 on: 25 April 2010, 14:39:22 »
My money is on the HBV at the back of the plenum under the screen scuttle.Looks a bit like the "starship enterprise"and have a nasty habit of causing a leak.Cost about £30=00 from stealers and are only advisable being replaced with a genuine item,not a cheapo egay jobbie.
Probably loose a bit of skin replacing it but not that hard a task.
Hope you are only topping up with 50/50 coolant mix as you will do a lot more damage just running on neat or low concentrate water.
Dracoro
  • Horsham, West Sussex
« Reply #2 on: 26 April 2010, 14:01:40 »
Had a water leak on mine, was thermostat/housing.
Richard A
  • Aldridge, West Midlands
« Reply #3 on: 26 April 2010, 14:53:56 »
Sounds like HBV, they tend to leak after the heater has been set at one temperture for a long period, sudden warm weather you reduce the temperture in the car, the HBV valve moves and leaks.
Just replaced mine £32.50 plus vat from GM.
regards
richard a
richard a
