Author Topic: Creaky squeaky B pillars  (Read 1277 times)
megaomega123
« on: 26 April 2010, 22:07:31 »
My drivers side B pillar has always been a bit creaky but now the passenger side is doing the same. It is only on bumpy surfaces and jolty braking and acceleration.
It's very annoying but I can't replicate when not driving to be able to pinpoint the source.
Any ideas from experience?
MickAP
  • South Derbyshire
Re: Creaky squeaky B pillars
« Reply #1 on: 26 April 2010, 22:12:14 »
Do you mean the door's creaky? If so the door striker plate needs adjusting, on the pillar.
Had the same with mine, a bit fiddly getting it perfect but that was the problem. :y
Mick ;)
« Last Edit: 26 April 2010, 22:14:16 by MickAP »
megaomega123
« Reply #2 on: 26 April 2010, 22:15:02 »
Door striker plate needs adjusting, on the pillar.
Mick ;)
I am not sure it is the same thing as I recently followed the cabin noise reduction how to. All plates have been adjusted and I would consider spot on. The noise seems to bee higher up the pillar, where the seatbelt comes out, so it is right in my ear >:(
MickAP
  • South Derbyshire
« Reply #3 on: 26 April 2010, 22:24:14 »
Mine was a lower down creaking :o  sort of around the top of the door card.
Your's maybe seatbelt :-/ Don't know
Mick
« Reply #4 on: 26 April 2010, 22:27:02 »
Are you sure it isn't the door locking pins rattling? :-/
manny
  • bromorough.Wirral.
« Reply #5 on: 26 April 2010, 22:47:00 »
Its the rubber round the door that is more than likely to blame. I sprayed some silicone spray on the door rubber and it cured it.
2001 OMEGA MV6
