Author Topic: Broken Locking Wheel nut  (Read 3450 times)
ianu
  • Oxfordshire
    • XC90/Maserati QPV/CooperS
« on: 25 April 2010, 21:20:26 »
Hi all,
This is slightly off mark I'm afraid - but hopefully I can draw on some of the vast experience on here. My other car is a Volvo XC90 (begins with a V doesn't it  ::) 0.
Probably know as one of those 'oh no!' moments.
Today as I attempted to remove one of the wheels - with the Locking Wheel Nut adapter in place and socket bar attached - as I turned it anti clockwise to undo it - the head of the nut with the keyway in it sheared off and came away leaving the stud still attached to the hub....
The stud has what looks like a small torx style head on it that might be possible to get some purchase on - but nothing I had in my toolbox (torx or socket) will get enough grip on it.
The collar piece that has sheared off has a radial crack in it which then failed completely by the look of it.
Does anyone have any experience of getting the rest of the stud out - is it a dealer job to get the right tool that can fit the stud head that is exposed - or should an experienced  indy garage be able to tackle this without wrecking the wheel and hub ?
Having already had all the other 3 wheels off - I very carefully went round and removed all the other locking nuts and replaced with standard studs - just in case a trend lining up to happen in 3's..
Any guidance - much appreciated.
Cheers
Ian.
Re: Broken Locking Wheel nut
« Reply #1 on: 25 April 2010, 21:26:02 »
might be worth buying some 'magic' sockets which will cut and dig into the stud
ianu
  • Oxfordshire
« Reply #2 on: 25 April 2010, 21:30:01 »
Thanks Tunnie - any idea where I'd find them - or will a search on 'magic sockets' be all I need..
tidla
  • solihull
« Reply #3 on: 25 April 2010, 21:31:06 »
Miggster
  • Taunton
« Reply #4 on: 25 April 2010, 23:36:03 »
Where in the uk are you
FOR SALE!!!! 1991 astra MK2 convertible, ONLY 34,000 genuine miles!!!!, very very good condition, Roof has no leaks nor rips, good solid engine, head gasket done @ 29,000 miles
only 3 prev owners,   £1,249
Hannah Judes Dad
    • the misses round the bend
« Reply #5 on: 26 April 2010, 19:43:33 »
ianu
  • Oxfordshire
« Reply #6 on: 26 April 2010, 22:18:41 »
Thanks all (I'm in Bicester near Oxford - work near Reading though)
Had a closer look at this this evening and the tip of the stud left in the wheel is actually the centre of the bit that fits into the 'socket key'. ie if you think of the socket as an odd shape pastry cutter that fits into a same shape keyway on an otherwise smooth face of the stud - the bit I've got left is the bit that fits inside the 'pastry cutter' - it's no more than 5mm across and 1mm deep and it's rounded off most of its corners.
I don't think any of the socket solutions will touch it.
Although the 'socket' (cutter) will grip whats left - there is no way I can keep it from lifting off when I try and turn it.
I think it's going to be a challenge with some drill bits to try and weeken whats left enough to shear the top off - a friend has offered the use of some bolt extractors which will still require drilling it.
Some creative use of Araldite has got me thinking though.....
I'll keep you posted - currently it's booked into the garage next week for them to have a go - but I'll keep trying too.
Cheers
Ian
« Reply #7 on: 26 April 2010, 22:22:52 »
- a friend has offered the use of some bolt extractors which will still require drilling it.  .....
Careful with easy outs/ez outs It's difficult getting them out if they break in use, they're hard.
ianu
  • Oxfordshire
« Reply #8 on: 26 April 2010, 22:25:17 »
Thanks Andy - I know - been there too - a long while ago mind...
Hannah Judes Dad
« Reply #9 on: 26 April 2010, 22:26:39 »
Careful with easy outs/ez outs It's difficult getting them out if they break in use, they're hard.[/quote]
Do they have flick knives? or are they from Liverpool?  ;D
ianu
  • Oxfordshire
« Reply #10 on: 26 April 2010, 22:29:33 »
;D ;D ;D excellent I needed a laugh - cheers  ;)
« Reply #11 on: 26 April 2010, 22:30:09 »
that'd be .... well 'ard!   ::) :y  :y
Hannah Judes Dad
« Reply #12 on: 26 April 2010, 22:42:37 »
I thought that was the dog on Deadenders  :D
« Reply #13 on: 26 April 2010, 22:54:15 »
I wouldn't know .......  :-?  :y
Hannah Judes Dad
« Reply #14 on: 26 April 2010, 22:56:45 »
I gave up watching it about 15 years ago so I don't have much of a clue either  :y
