Author Topic: AutoBox Electrics not working?  (Read 712 times)
Jezzer
  • Herts
« on: 27 April 2010, 21:26:01 »
Hi All
I have a 2.0 16v Auto, I am having some electrical issues?
Initially no Info Panel, now working? dodggy audio fitment - wiring butchered? BUT battery failed so fitted new one. starts and runs fine except 'Auto Box' seems to be stuck in 'Winter Mode' i.e try's to pull away in third? NO Leds for gear selector, No Sport Mode, No Kickdown, and I have to shift Box Manually? Have replaced fuse '9' 10amp as it had blown, worked briefly but then stopped. Fuse not blown still not working? is there a re-set procedure? or anything else I can do.................
Welung666
Re: AutoBox Electrics not working?
« Reply #1 on: 27 April 2010, 21:32:15 »
Have a look in the maintenance guides for cleaning the selector switch. Apart from buying some switch cleaner it's free to try and may just cure the problem ;)
