Author Topic: warning check  (Read 944 times)
dave10
  • sunderland
warning check
« on: 29 April 2010, 09:38:19 »
hi all wondering if yous can help (again) i got in the car thismorning and after a few seconds i got a headlamp field/vision warning on display any ideas anyone it does have xenons if that helps
Re: warning check
« Reply #1 on: 29 April 2010, 09:53:49 »
It's a warning from the headlamp levelling system of a problem. Have the headlights also dipped down very low?
Needs a Tech 2 to read the codes from the levelling ECU to see what's failed, but a quick check that the arms are still attached on both level sensors (on the front and rear passenger side of the suspension) and a clean up of the electrical connections to the above might save you the bother. :y
