Author Topic: omega 2.5 td lurching  (Read 906 times)
dave2.5td
« on: 28 April 2010, 18:48:35 »
my omega 2.5 td keeps nearly cutting out when i go from first  to second and engine warning light comes on and goes back off after a few seconds then i get power again can anyone help :)
Welung666
Re: omega 2.5 td lurching
« Reply #1 on: 28 April 2010, 18:51:03 »
Where are you Dave?
Have you tried paperclip testing it?
Omegatoy
  • UK
« Reply #2 on: 28 April 2010, 20:26:20 »
oh dear!! old story have you tried doing a search?
 its been covered mny times on here,
 you need to fill a new fuel filter with diesel magic, top with diesel then run car for at least twenty mins using varying throttle positons, this will hopefully clean all the crap out of the throttle potentiometer in the pump which usually but not always causes this symptom, it my need to be done a couple of times but it will help if not affect a cure
« Last Edit: 28 April 2010, 20:27:10 by Omegatoy »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 29 April 2010, 14:04:33 »
Comma Diesel Magic - around six quid a bottle from Halfords.
Always the first course of action with these symptoms :y
If you can do the paper-clip test, it'll probably show the dreaded '64' ;)
