Author Topic: V6 Vectra  (Read 1983 times)
V6 Vectra
« on: 30 December 2007, 21:56:03 »
Ive got a mate that has just been on the phone saying he has a problem with his Vectras brakes. He says that when the engine is off and he pumps the brake pedal he can get good pressure but as soon as he starts the engine the pedal hits the floor and he's got no brakes. oh yeah hes just replaced the ABS unit. So any ideas. :y
    • 530D M Sport, 330i Coupe
Re: V6 Vectra
« Reply #1 on: 30 December 2007, 21:58:26 »
Could be air bubbles trapped in the ABS modulator, requires pressure bleeding while 'excercising' the ABS Modulator with Tech2.
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: V6 Vectra
« Reply #2 on: 30 December 2007, 22:01:56 »
aye be worth bleeding the system through...
When you say replaced brakes, do you mean just discs & pads? or calipers, etc...
Just also sounds like what happens when the valve pops out in the servo if you push back too hard on the pistons in the calipers...
« Last Edit: 31 December 2007, 00:07:22 by PaulW »
Humbugs...
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
Re: V6 Vectra
« Reply #3 on: 30 December 2007, 23:30:15 »
sounds like a servo problem to me
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: V6 Vectra
« Reply #4 on: 30 December 2007, 23:59:09 »
THIS WILL GET MOVED TO GENERAL CHAT PETE AS DID MY QUESTION  ON VECCY DID BY AA.regards pete for the new year. ::)
Jaguar XJ6
Markjay
  • London
Re: V6 Vectra
« Reply #5 on: 31 December 2007, 00:09:25 »
...it is already in General Chat...  :o
Alas, no more Omegas....
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: V6 Vectra
« Reply #6 on: 31 December 2007, 03:32:20 »
I think he meant General Help?
(Servo, inlet manifold pipes / pressure).
Re: V6 Vectra
« Reply #7 on: 31 December 2007, 07:56:43 »
IF its hitting the floor it has air in the system somewhere......and a favourite is the ABS unit.
Hence why when they go (the later vectra uses the same unit as the Omega) its best just to change the ECU...
Re: V6 Vectra
« Reply #8 on: 31 December 2007, 10:30:06 »
Thanks for the advice fellas :y
markey mark
  • SLady bitshorpe north lincs
Re: V6 Vectra
« Reply #9 on: 31 December 2007, 14:18:30 »
pressure bleed it bud nothing on just the air pressure will blow all sorts of trapped air out !! ;)
MikeDundee
  • Costa Del Peckham
Re: V6 Vectra
« Reply #10 on: 31 December 2007, 14:20:58 »
Anytime Pete ;D ;D
