Author Topic: cloudy projector headlamp lenses  (Read 1254 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« on: 28 April 2010, 21:03:38 »
the lenses on my projector headlight are very cloudy dull what's the best way to bring them back to life ?
2001 MV6 3.2 manual been converted from 2.6 auto
    • 530D M Sport, 330i Coupe
Re: cloudy projector headlamp lenses
« Reply #1 on: 28 April 2010, 21:17:28 »
Some G3 compound seems to do a good job or a very fine wet and dry paper.
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
« Reply #2 on: 28 April 2010, 22:07:33 »
You could try Brasso, test in a corner first.
MutantCav
  • Gainsborough
« Reply #3 on: 28 April 2010, 22:09:43 »
Or give them a good t-cutting
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 28 April 2010, 22:40:02 »
Easy peasey answer to this one.
Use cheap WHITE toothpaste, plenty of water and plenty of rubbin'. I kid you not !
Amazing as it sounds, it works fantastically, PLUS your car finishes up all minty fresh. Allow a good 30 mins per light and plonk on as much toothpaste as you wish.
I found Lidl's "elcheapo" dentalux brand to be VERY good. Have a go and report back....suspect you'll be as gobsmacked as I was. Who would have thought. ?
Skint
« Reply #5 on: 30 April 2010, 10:06:19 »
I used Brasso on my regular lamps, they are no longer yellow although there is still a crazed pattern in places on them! I also used a rubber sanding block from Halfords to help apply pressure.
