Author Topic: paper clip test  (Read 2052 times)
kevyn
  • hertfordshire
paper clip test
« on: 30 April 2010, 10:00:52 »
Hi, being a newbie and loving my 157,000-no problems- v_reg-2.5 omega (until now), i was wondering if anyone can show me a link to the famous 'paper-clip' code test? The orange managentment light has just come on and it's a tiny bit sluggish now. The dealer wants £100 just to give me a code which i find absolutely disgusting.  :-/
Welung666
Re: paper clip test
« Reply #1 on: 30 April 2010, 10:08:35 »
Link is below in my signature ;)
kevyn
  • hertfordshire
Re: paper clip test
« Reply #2 on: 30 April 2010, 12:03:30 »
good show that man :) here goes......
Welung666
Re: paper clip test
« Reply #3 on: 30 April 2010, 12:28:52 »
Hurry up.... I'm running out of nails ;D ;D ;D
kevyn
  • hertfordshire
Re: paper clip test
« Reply #4 on: 30 April 2010, 12:59:28 »
give that man a gold star! :) genius :) Vauxhall wanted £100 for that! The code i can count is 135 and 82. no idea where the telltale is or injector valve is though  ;D
kevyn
  • hertfordshire
Re: paper clip test
« Reply #5 on: 30 April 2010, 13:02:40 »
Typical. gets me to 27 countries through europe (twice) and Bulgaria (twice) for years, then breaks down in bighty  ;D
Welung666
Re: paper clip test
« Reply #6 on: 30 April 2010, 13:26:15 »
Telltale you can ignore, it's a warning that the bulb you watched flash isn't working ;D ;D
Check the plug for injector 2 is clean, dry and fully pushed home. :y
Re: paper clip test
« Reply #7 on: 30 April 2010, 13:31:13 »
82   Injector Valve 2 Voltage Low
135   Telltale (Checklight) Voltage Low
82 is the key one, have you had any work done on the car recently?
Check the plug to the injector it self and also check the wiring room for the injector setup multiplug at the back of the passenger cylinder head for wiring damage
kevyn
  • hertfordshire
Re: paper clip test
« Reply #8 on: 30 April 2010, 14:39:34 »
heroes! :) one of the yellow plugs was loose. how? before i took off the top cover, i noticed a silver cylinder (bosche) attatched to the right side. does anyone know what this is? I seem to get a strange whinning noise from there as i start the engine and it goes off after a few seconds.
kevyn
  • hertfordshire
Re: paper clip test
« Reply #9 on: 30 April 2010, 14:52:05 »
Re: paper clip test
« Reply #10 on: 30 April 2010, 14:56:45 »
Idle Control Valve, Don't know why it'd whine on start up though, it's a motor driven valve that regulates air around the throttle valve.
Re: paper clip test
« Reply #11 on: 30 April 2010, 16:04:23 »
sucking air?
kevyn
  • hertfordshire
Re: paper clip test
« Reply #12 on: 30 April 2010, 19:36:50 »
could explain why it's running rough since i took it all apart to do the injector  :-/ doh!  ;D
Thanks for all your help guys. saved me a fortune  :y
« Last Edit: 30 April 2010, 23:26:35 by kevyn65 »
Page created in 0.047 seconds with 17 queries.
