Author Topic: climate control blowing hot all the time  (Read 1231 times)
GLENNY BOY
  • dartford
    • cd 2.6 auto v6 2002
« on: 01 May 2010, 16:02:42 »
hi all every time i put the climate conrol on i set it on low it still blows out warm/hot air. has it happened to anybody else ? has anybody got any ideas why this is happening thanks :y
Welung666
Re: climate control blowing hot all the time
« Reply #1 on: 01 May 2010, 17:13:24 »
Bertie has the same problem, hopefully he's coming over to me tomorrow for us to investigate. I'll let you know the outcome :y
GLENNY BOY
  • dartford
« Reply #2 on: 01 May 2010, 17:59:38 »
thanks :y
« Reply #3 on: 01 May 2010, 18:02:06 »
Needs regassing?
GLENNY BOY
  • dartford
« Reply #4 on: 01 May 2010, 18:04:22 »
i dont know does mine have a/c ???
cmeonthemove
  • Taverham, Norwich
« Reply #5 on: 01 May 2010, 18:09:48 »
If it's a CDX then yes. Is it blowing 'hot' air as in if you have the heaters turned right up, or just like you haven't got the air-con on? I'm guessing it's blowing air at ambient temp which suggests you need the system regassed, but get it done by a proper aircon technician as they can pressure check for leaks and vacuum out the system too.
Also check your coolant level as too low coolant will stop the condenser kicking in as I understand.
Chris
2.5 Elite
GLENNY BOY
  • dartford
« Reply #6 on: 01 May 2010, 18:13:37 »
yes its warm /hot air even set on low and even with climate control off it feels hot in the car :y
