Author Topic: Crankshaft sensor info and how to test  (Read 1574 times)
Goonybird
  • Northampton
  • Shouldn't have gone to Specsavers
« on: 02 May 2010, 11:56:48 »
Posted elsewhere re: starting problems on an X25XE. It appears Crank sensor is worth looking at as advised.
These should answer various queries I have seen posted on here recently.
I have trawled internet and come up with these snippets:
This is how to test a sensor:
http://www.vauxhallownersnetwork.co.uk/showthread.php?39425-Vectra-How-to-check-a-V6-crank-sensor
Also from another forum, the crank sensor itself is earthed through where it connects to the block. So worth removing sensor and cleaning faces of sensor and block to ensure a good connection.
Hope it doesn't contravene Forum regs posting links to other forums.  :-/
Stef
Have owned: Opel Manta A 1900 Auto Berlinetta, Opel Manta B 2.0 Auto Berlinetta, Vx Royale Coupe 2.8 Auto, various non Vx, Skoda Superb 130tdi currently Omega 2.5CDX - now Octavia vRS WRC
Smooth
  • N.Ireland
Re: Crankshaft sensor info and how to test
« Reply #1 on: 02 May 2010, 15:46:41 »
Crank sensors do give abit of bother,
Ensure ignition is switched off
Disconnect CKP sensor multi plug
Check resistance between terminals 1 and 2 with an ohm meter... should be between 500 - 800
If Jesus had a licence he would drive an MV6
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
« Reply #2 on: 02 May 2010, 15:48:11 »
Maybe this info could be added to the relevant "How to " thread
Page created in 0.027 seconds with 16 queries.
