Author Topic: V6 cam belt  (Read 2569 times)
V6 cam belt
« on: 02 May 2010, 00:07:05 »
I've changed one before ... about 4yrs (well ..... maybe 4 & half yrs ago) but I've question.....  :-/
The lower eccentric tensioner on a 3.0 car  :-/ what's it do? I know you could obviously say it tensions the cam belt, but as the last 2.6/3.2 cars have a fixed bearing it implies that it doesn't do that much.
The top/middle eccentric tensioner times 1 & 2 cams to 3 & 4 cams but I can't see what the relevance of the lower eccentric is.
What am I missing  :-?  :-?  :y
pedroMV6
  • York
  • Der Metzgermeister
Re: V6 cam belt
« Reply #1 on: 02 May 2010, 00:13:21 »
You don't need me to tell you that Andy! ;D ;D ;D
Re: V6 cam belt
« Reply #2 on: 02 May 2010, 00:16:19 »
The lower one sets cams 3/4 into the correct position in relation to the crank - althoug as you say, on the later DBW cars, it's fixed-position :y
Re: V6 cam belt
« Reply #3 on: 02 May 2010, 00:18:56 »
err? thanks Pete!   ;) ;) :y
pedroMV6
  • York
Re: V6 cam belt
« Reply #4 on: 02 May 2010, 00:20:23 »
Any time, bud :y
At least James could answer your question though. ;)
Re: V6 cam belt
« Reply #5 on: 02 May 2010, 00:22:13 »
It's on the slack side of the belt, so it doesn't really have a bearing/influence on the 3/4 cam timing.  :-/  :-/
Re: V6 cam belt
« Reply #6 on: 02 May 2010, 00:23:37 »
Any time, bud :y
 ;)  ;)  :y
Re: V6 cam belt
« Reply #7 on: 02 May 2010, 00:27:15 »
Try turning the arrow away from the (approx) 1pm position... you'll notice cams 3/4 don't line up with the timing gauge anymore... so I'd say it does influence timing? (Or should I say, the tension set by the adjustment on that concentrc idler, adjusts the timing on 3/4 bank? )
Re: V6 cam belt
« Reply #8 on: 02 May 2010, 00:31:45 »
Crank rotates clockwise viewed from the front so it's the tight side  of the belt. :y
Re: V6 cam belt
« Reply #9 on: 02 May 2010, 00:32:26 »
I've thought about it .. you're right, it's not on the slack side is it, it's on the tension side ... which is why the sprung tensioner is on the other side of the crank.  :y
Re: V6 cam belt
« Reply #10 on: 02 May 2010, 00:33:18 »
As above, I've thought about Jame's post ......  :y
Re: V6 cam belt
« Reply #11 on: 02 May 2010, 00:35:39 »
The wind got up too much ... Jimbob didn't call   ;D ... so I called it a day. I just need the plenum  & the throttle cable fitting now. I'll finish it Monday  :y
Re: V6 cam belt
« Reply #12 on: 02 May 2010, 05:36:19 »
with the later cars, with set bottom idler, i wondered why the top middle idler cant be set as well? only setting needed would be tension....
machine tolerances perhaps...? :-/
Kaycee
  • Doncaster
Re: V6 cam belt
« Reply #13 on: 02 May 2010, 07:03:47 »
just  point i was thinking of buying one of those lazer kits is there a problem with them as i have to look at an oil that is suspect from the camshaft seal
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Kaycee
  • Doncaster
Re: V6 cam belt
« Reply #14 on: 02 May 2010, 07:05:14 »
edit(oil leak from the front i meant to say )
