Author Topic: TD Smokey on Startup  (Read 2525 times)
« on: 01 May 2010, 22:32:35 »
Is it normal for the 2.5 TD to be a bit smokey (dark smoke) on startup, clearing when engine up to temp?
Assuming glowplugs are new, what else to look for aside of filters and such... common problem?
Welung666
Re: TD Smokey on Startup
« Reply #1 on: 01 May 2010, 22:42:17 »
I just the lightest waft of dark smoke after the glow plugs have been on, clears pretty much right away though.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 01 May 2010, 22:48:34 »
Pretty much as Wellung says ......
First few revs, literally, and then pretty well clear James.
Is it starting pretty well 'on the button'?
« Reply #3 on: 01 May 2010, 22:53:42 »
Starts without fault, but is smokey for around 5 mins.
Then clears, and continues to run great.
Is it common, or, do I walk?  ::)
tidla
  • solihull
« Reply #4 on: 01 May 2010, 22:59:41 »
whats the mileage?
injector cleaner in the tank. injectors not atomising untill cyl temp rises? :)
Seth
« Reply #5 on: 01 May 2010, 23:00:21 »
Asking the obvious James:
Oily or fuelly smoke?
Is it getting up to operating temp - knackered 'stat etc?
« Reply #6 on: 01 May 2010, 23:03:51 »
130k miles
I really only have limited info - it's a gamble on whether or not to purchase at a reasonable cost.. . :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #7 on: 01 May 2010, 23:55:42 »
Check VERY carefuly the hose on the intercooler or intake side as this can cause exesessive smoke on start up. In fact check all the pipes and hoses while your at it. if your sure that all are ok then a bottle of diesel magic may cure it .
Jaguar XJ6
hoofing it
« Reply #8 on: 02 May 2010, 07:06:32 »
could be oil in the charge pipe/manifold take the charge pipe off and have a look if its totaly running with oil walk away turbo feked.
if its a fuel smoke try cleaning the injectors and diesel magic it also check codes. :y
Omegatoy
  • UK
« Reply #9 on: 02 May 2010, 08:17:16 »
130k nothing, if its black smoke until its warm but no other seen faults i would assume the car has done a lot of very short journeys and is coked up!, test drive will tell, limited info? have you not seen the car yet then?
could do with a little more infor to be honest
Omegatoy
  • UK
« Reply #10 on: 02 May 2010, 08:27:36 »
just reread it and black smoke suggests unburnt fuel, which could be any number of things what year is the car? npersonally if its cheap enough then i would buy it cos they are very easy to sought out!!
« Reply #11 on: 02 May 2010, 11:12:22 »
If it turns over a couple of times before firing, that can make them smoke. Or if a couple of glowplugs are down.  Poor fuel doesn't help.
Seth
« Reply #12 on: 02 May 2010, 11:51:19 »
My initial thoughts, but after re-reading James' post, the smoke persists for around 5 mins.
Personally, I'm thinking some TLC here - a damn good service, a good drink of Diesel Magic, and an 'Italian Tune-up'
Omegatoy
  • UK
« Reply #13 on: 02 May 2010, 16:59:11 »
had same thoughts while i was resprayiing a vw camper today!!
 :y :y :y
« Reply #14 on: 02 May 2010, 17:06:45 »
I didn't win the auction in the end. Missed it by a few quid  :'(
