Author Topic: Banjo Bolts?  (Read 1513 times)
I_want_an_Omega
Banjo Bolts?
« on: 02 May 2010, 16:52:41 »
Ok, so where are they used in the car, and why are they called Banjo?
Am I going to encounter any if I change my thermostat?
Thanks
KW
Re: Banjo Bolts?
« Reply #1 on: 02 May 2010, 16:59:18 »
Anywhere where there is likely to be large amounts of pressure in the fluid line (eg, brakes, clutch, fuel).
Because of their shape.
No.
I know violence isn't the answer, I got it wrong on purpose.
Smooth
  • N.Ireland
Re: Banjo Bolts?
« Reply #2 on: 02 May 2010, 17:02:27 »
When i'm cleaning windows!! ;D
If Jesus had a licence he would drive an MV6
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
Re: Banjo Bolts?
« Reply #3 on: 02 May 2010, 17:02:50 »
A Banjo bolt is basicly a ring with a bolt through the centre. The bolt has a hole through the centre and an other hole at right angles to it below the shoulder, the ring will have a hose attached and the combination allows fluid/gas to flow between the two forming what would now be an elbow joint in pipework for low pressure applications. Banjo bolts are usually found in high pressure application such as brake fluid lines.
I_want_an_Omega
Re: Banjo Bolts?
« Reply #4 on: 02 May 2010, 17:27:01 »
Thanks guys ........
Re: Banjo Bolts?
« Reply #5 on: 02 May 2010, 19:09:43 »
Main use in the Omega is oil cooler, if you replace it, make sure you buy brand new ones for re-fitting as the little gits have a tendency to sheer off
Re: Banjo Bolts?
« Reply #6 on: 02 May 2010, 20:29:05 »
Two in the coolant bridge as well ;)
Page created in 0.021 seconds with 16 queries.
