Author Topic: Car Pulling to the left  (Read 1486 times)
marlcdx
  • Stoke on Trent
« on: 02 May 2010, 10:42:47 »
Hi.  My car is pulling really bad to the left, I have had it tracked but this has made no difference at all.  Its also had a new track rod arm fitted (tracked after).  I have also noticed the steering wheel isn't straight.  Any idea's.
tidla
  • solihull
Re: Car Pulling to the left
« Reply #1 on: 02 May 2010, 10:47:32 »
switch the tyres around, front to back. ;)
Smooth
  • N.Ireland
« Reply #2 on: 02 May 2010, 10:50:39 »
Did you get 4 wheel alignment done,is the tyres wearing on inside/outside,if so swap them opposite and check tyre pressures :y
If Jesus had a licence he would drive an MV6
marlcdx
  • Stoke on Trent
« Reply #3 on: 02 May 2010, 10:53:41 »
Didnt get a four wheel track?  There is no abnormal wear on the tyres and the pressure is fine to.  what about the wheel not being straight, what would cause this?
Smooth
  • N.Ireland
« Reply #4 on: 02 May 2010, 11:10:04 »
Was the steering wheel straightened and clamped before alignment,if so car is not aligned properly.I would recommend a 4 wheel alignment and also check the correct part was fitted
marlcdx
  • Stoke on Trent
« Reply #5 on: 02 May 2010, 11:16:48 »
No mate.  They didnt clamp the wheel before tracking the car.  Is this why my steering wheel isn't straight either.  Do most trye places do this 4 wheel alignment then i.e quickfit for example
Smooth
  • N.Ireland
« Reply #6 on: 02 May 2010, 11:21:05 »
Thats what the problem is mate,i'm not sure what garages would do the 4 wheel alignment,quickfit should,i would enquire first... shouldn't cost much more.I know over here in N.Ireland its 20 quid for the 4 wheel tracking
marlcdx
  • Stoke on Trent
« Reply #7 on: 02 May 2010, 11:35:47 »
Great Stuff.  Cheers for help.
PxMetro
  • Stamford
  • Maryland Cookies are brilliant for dunking
    • 3.2 MV6 Estate
« Reply #8 on: 03 May 2010, 07:36:56 »
This is sound advice! Save yourself a few quid up front by changing the front wheels with the rears, to eliminate the tyres from the equation  :y
