Author Topic: De-badging  (Read 2681 times)
cmeonthemove
  • Taverham, Norwich
De-badging
« on: 02 May 2010, 20:52:50 »
What would you recommend for getting rid of the adhesive left behind when removing the badges from the bootlid?
Chris
2.5 Elite
Welung666
Re: De-badging
« Reply #1 on: 02 May 2010, 20:58:03 »
Hairdryer and lots of patience!
pedroMV6
  • York
  • Der Metzgermeister
Re: De-badging
« Reply #2 on: 02 May 2010, 21:05:49 »
Meths. ;)
yorkipud
  • yorkshireman in Aberdeen
Re: De-badging
« Reply #3 on: 02 May 2010, 21:11:06 »
I've always taken as much off with my fingers/nails without damaging paintwork, then t-cut does the rest also helps to blend in any colour difference ;)
YORKSHIRE AND PROUD
Smooth
  • N.Ireland
Re: De-badging
« Reply #4 on: 02 May 2010, 21:19:34 »
Hair dryer or heat gun then tcut as said above,works everythime :y
If Jesus had a licence he would drive an MV6
Re: De-badging
« Reply #5 on: 02 May 2010, 21:20:32 »
WD40. Let it dry for about a minute, it makes it go hard then it picks off in larger lumps.
« Last Edit: 02 May 2010, 21:21:03 by LSG_1 »
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
Re: De-badging
« Reply #6 on: 02 May 2010, 21:21:20 »
What you need is a "Caramac Wheel" or "Toffee Wheel" it fits on to your drill/electric screw driver and removes the adhesive in seconds without any damage to the paint, I have one and its so simply to use, I removed a door strip and it took me about a minute to remove the adhesive along the full length of the door, you can get them from any Auto Paint Suppliers or ebay link below
http://cgi.ebay.co.uk/STRIPE-REMOVAL-WHEEL-RUBBER-CARAMAC-WHEEL-/120564096889?cmd=ViewItem&pt=UK_Body_Shop_Supplies_Paint&hash=item1c122e1f79
This one is cheaper
http://cgi.ebay.co.uk/Automotive-Toffee-Whizzy-Stripe-Removal-Wheel-/350329202253?cmd=ViewItem&pt=UK_Body_Shop_Supplies_Paint&hash=item51913f664d
« Last Edit: 02 May 2010, 21:28:07 by jim »
vic
  • Aldershot (Hampshire)
Re: De-badging
« Reply #7 on: 02 May 2010, 22:24:49 »
I've always used white spirit. Allow 30 secondsfor the glue to soften and it will come off easily. White spirit has always cleaned off almost every glue I've come across with the exception of super glue (cyanoacrylate), acetone (nail varnish remover) will cope with that. Never found one that will deal with epoxy resin yet though.
HTH
VC ;)
cleggy
Re: De-badging
« Reply #8 on: 02 May 2010, 23:54:23 »
Probably a silly question, but why would you want to de-badge in the first place?
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
Re: De-badging
« Reply #9 on: 02 May 2010, 23:56:28 »
i used lighter fluid when i debadged my mv6 just dont smoke while you do it
2001 MV6 3.2 manual been converted from 2.6 auto
bigtow
  • rochester kent
Re: De-badging
« Reply #10 on: 02 May 2010, 23:57:15 »
why advertise what you got
cleggy
Re: De-badging
« Reply #11 on: 03 May 2010, 00:11:15 »
Or not, as the case may be  ;D.
The question remains WHY?
The car is what it is as supplied by the manufacturer, is it not?
Dany
  • Belgium
Re: De-badging
« Reply #12 on: 03 May 2010, 00:20:55 »
I'm interested too, to replace my original badge for an Irmscher one. This may explain perhaps? ^^
In passing, anyone know how to remove the Opel badge on the steering wheel...? (To replace for an "i" badge, for the explanation) :p
« Last Edit: 03 May 2010, 00:23:21 by moudufond »
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: De-badging
« Reply #13 on: 03 May 2010, 04:41:32 »
I use variant of spraying thinners called 'gun cleaner'. Pre-paint was another name for it. It works on all surfaces and I have used it over many years on all types of finishes, interior and exterior without any damage at all - expect to the residual adhesive that is which just wipes away with a soft lint free cloth. Any sprayshop will probably give you a bit if you take a small bottle. Remember NOT to smoke while using it! :D
cmeonthemove
  • Taverham, Norwich
Re: De-badging
« Reply #14 on: 03 May 2010, 08:30:38 »
Thanks for all the suggestions guys  :y
I'm removing the 'Vauxhall' badge and moving the 'Elite' badge to under the boot handle to clean the look of the bootlid up a bit - all part of the Opel badge conversion. I've also got a (old) small dent under the Vauxhall badge which I intend to sort out while I'm at it. The badges have also lost quite a bit of the chrome.
« Last Edit: 03 May 2010, 18:34:09 by cmeonthemove »
Chris
2.5 Elite
