Author Topic: LPG fitting  (Read 2645 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
LPG fitting
« on: 03 May 2010, 18:32:57 »
Anyone on here fancy helping fit LPG to v6 would be paid but could do with your experience!how long would it take? :yo
scream if you want to go faster!!!
Re: LPG fitting
« Reply #1 on: 03 May 2010, 18:45:24 »
Might be, but usually its diy then ask on here as you go.
What kit do you have?
mr ICE man
  • dolgellau wales
Re: LPG fitting
« Reply #2 on: 03 May 2010, 18:59:58 »
Not sure yet just bought it off eBay and is currently on a v6 I'm going down to remove it so should see how it goes but would like some help!
Re: LPG fitting
« Reply #3 on: 03 May 2010, 19:12:28 »
its a 3 day job assuming all goes well, beware the kits of eBay are just the basics. You need a lot more than what you get, loads of water pipes, brackets, bolts, this was the everything i needed:
mr ICE man
  • dolgellau wales
Re: LPG fitting
« Reply #4 on: 03 May 2010, 19:16:27 »
As it's on a working omega I guess all the bits are there and I'm hoping to keep the heads so won't have to drill mine!
Re: LPG fitting
« Reply #5 on: 03 May 2010, 19:18:51 »
Its second hand SGI install?
Re: LPG fitting
« Reply #6 on: 03 May 2010, 19:22:12 »
2nd hand kits may end up a false economy... I hope you get the lead and software to calibrate it :-?
If you're removing it then make sure you take lots of pictures and notes about where everything connects to. You'll need new pipework anyway so I'd advise going for Polyflex... It's easier to work with :y
mr ICE man
  • dolgellau wales
Re: LPG fitting
« Reply #8 on: 03 May 2010, 19:26:23 »
Echo above, kit we use (Stag) is well used on forum, comes with diagrams and can get lot of support here. Its also got good diagnosis and works well.
Second hand could be whole tin of worms, second hand tanks also need to be pressure tested if older than 10 years, you going to have to get new pipe work anyway such as polyflex/copper, you might want to spend few extra quite and buy a new kit which has warranty and documentation.
V6 Stag kit is £600  :y
Re: LPG fitting
« Reply #9 on: 03 May 2010, 19:28:18 »
Hav a look! http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130386957526&ssPageName=STRK:MEWNX:IT#ht_500wt_948
Personally i would steer well clear of that, its a completely unknown system, you don't know if its SGI or Mixer, you have no idea how its been wired in, couple of crappy basic photos, nothing of the front end!!!
Its also very expensive....
mr ICE man
  • dolgellau wales
Re: LPG fitting
« Reply #10 on: 03 May 2010, 19:30:44 »
That case I won't do it!thanks all!Thought would be easier coming off a car but lack knowledge again!
Re: LPG fitting
« Reply #11 on: 03 May 2010, 19:34:32 »
Your relying on seller removing it correctly, and getting it all.
The actual components of LPG are not that expensive, its all the other little bits of the kit which make up the cost.
Its worth going for a new kit, just take that little bit longer to pay off.
I had some help, so even extra costs like hotel and food for said guests bumped conversion costs up slightly, but at end of the day, meant it would take just a few more weeks to recover the cost.
Remember, £600 investment in LPG, will take about 10k miles to re-pay
Re: LPG fitting
« Reply #12 on: 03 May 2010, 19:38:30 »
If you go down there to collect it then just make sure you have everything... I don't agree with Tunnie that it's too expensive. £200 is a big saving on the tank/front end as long as it's a recent installation :y
But with no documents/software/leads it will be a real nightmare to fit :y
Re: LPG fitting
« Reply #13 on: 03 May 2010, 19:41:20 »
Was about £480 for tank, and front end kit for me. Add on postage at £240, i'd say thats expensive for second hand, unknown kit which has most likey done a lot of miles
mr ICE man
  • dolgellau wales
Re: LPG fitting
« Reply #14 on: 03 May 2010, 19:43:45 »
What does everyone mean by software?
