Author Topic: oil cooler pipes on 2.5 tdi  (Read 1350 times)
kevsabo
« on: 01 May 2010, 14:21:06 »
Hi folks
just wondering if any one has had to change the oil cooler pipes on 2.5 tdi (bmw)???
Mine has developed a pin prick leak where its corroded through!! looks like a bit of a job to change it!!
Would it be possible to chop out the corroded bit and replace with a small legnth of suitable rubber hose and clips???
or havei got to change it??
Car doesnt use to much oil its just dripping on my drive, other than that all seems ok.
if any ones got any suggestions or easy fixes i would appreciate some info
regards  kev
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: oil cooler pipes on 2.5 tdi
« Reply #1 on: 01 May 2010, 18:32:58 »
Why not try splitting a rubber hose lengthwise and clamping over the leak with jubilee clips? A quick fix  if it works. :y
« Last Edit: 01 May 2010, 18:33:30 by ci643215 »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #2 on: 01 May 2010, 20:00:15 »
Same thing happened to me
The Oil is under pressure & you must use steel piping accoding to my mechanic
Vx changed the pipes & fittings at one time & the earlier ones are no longer available, so you have to change both pipes & all of the bracketing that support them
I was quoted £60+ for a single pipe so managed to get a complete set with all of the fittings from a breaker on e-bay for £20
Mine leaked where it had rubbed as it passed through the body. I was told that had it failed all of the oil would have been dumped very quickly & bye-bye engine
Have never been able to clean up my drive!
P.S. I have pdfs of both the earlier & later types so can e-mail them to you as attachments if you PM me with your normal e-mail address
« Last Edit: 01 May 2010, 20:03:00 by Pitchfork »
hoofing it
« Reply #3 on: 01 May 2010, 21:23:11 »
Hi folks
regards  kev
as you say bridge it out and use hose clips I used fuel pipe :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 01 May 2010, 23:07:55 »
Personally, I'd be looking at replacing 'em.
If that pin-hole develops further, you'll VERY rapidly dump the entire sump's quantity and say goodbye to the lump. By the time the warning light comes to your attention, it may well be too late.
You may find that the pipe has chaffed near the oil cooler. As a precaution, I've sleeved some hose between mine at this point. :y
« Last Edit: 02 May 2010, 10:39:14 by Reliance505 »
Omegatoy
  • UK
« Reply #5 on: 02 May 2010, 08:29:51 »
if any bodged repair fails say goodbye to the engine!! look up pertek or similar hose/hydraulic people who will make you a copy iof your original hoses for a reasonable price
kevsabo
« Reply #6 on: 04 May 2010, 13:46:22 »
Hi thanks for your advise regarding my leaky oil cooler pipes
can you send pdf's to
kevsabo@blueyonder.co.uk
regards Kev
