Author Topic: ECU Fault Codes and Autobox in Safe Mode  (Read 1731 times)
Jezzer
  • Herts
« on: 03 May 2010, 11:48:29 »
Hi All
Paper Clip Test Done   (Thanks TheBoy!)
Fault Codes:
0130: 02 Sensor Circuit Voltage Low
0130: 02 Sensor Circuit Voltage High
0130: 02 Sensor Range/Performance
1690: Telltale (Check Light) Voltage High
1690: Telltale (Check Light) Voltage Low
Can anyone explain where I need to look? is an earthing issue, power supply???? AND how these faults maybe connected to my AutoBox being stuck in 'limp mode'???
All other functions on the car are fine.......
Cheers
Welung666
Re: ECU Fault Codes and Autobox in Safe Mode
« Reply #1 on: 03 May 2010, 12:05:10 »
P0130 would put the car into limp mode to protect the cats from damage due to over fuelling. Check the wiring from the 02 sensor back to the plug. Also check the plug is clean, dry and fully pushed home as a simple starting point.
Jezzer
  • Herts
« Reply #2 on: 03 May 2010, 12:19:01 »
Thanks very much, will look now.... according to Haynes Manual its close to the back of the Gearbox where the prop shaft joins?
Let you know how get on?
« Reply #3 on: 03 May 2010, 14:42:52 »
Agreed - as I originally stated more likely to be an engine issue putting gearbox into safe mode. http://www.omegaowners.com/forum/YaBB.pl?num=1272725694/0#2
Jezzer
  • Herts
« Reply #4 on: 03 May 2010, 15:15:45 »
Hi All, checked o2 Sensor, looks clean and fairly new, wiring sound, connectors all seem OK? (could the actual sensor be faulty?)
Will try Paper Clip test again to see if get the same codes?
Seems odd that this fault came about straight after my original battery failed and blew a fuse?
I repalced the fuse and fitted a new High Power Battery and it still won't come on? Getting Very Frustrating  >:(
« Reply #5 on: 03 May 2010, 19:50:42 »
What are the symptoms of the engine?
Jezzer
  • Herts
« Reply #6 on: 03 May 2010, 20:42:35 »
That's what's so odd? There are none?
It starts first time every time, uses virtually no oil or water, runs crisp and smooth, good mpg?
I did have some issues BEFORE I replaced the battery last week tho': sluggish starting..... battery knackered!
Engine ran hot (new rad stat for cooling fan fixed it)
Idle was 'hunting up and down between 1,000 & 1,500 rpm but only when very hot, fine when at normal temp
Info display didn't work (bad connections)
Cruise not working (is now?)
Radio cutting out (fixed now I have put in my Sony MP3)
Autobox worked fine all the time - hasn't worked since battery replaced? ALL other faults GONE!
p.s. Checked ATF Fluid and good colour (deep red) and fully topped up.
HTH and Andy B said maybe dodgy 02 Sensor?
Happy to change if I knew that was the problem......
STUMPED?  ::)
Happy to pay you to have a look and help 'identify' the main issue, i.e. ECU reset new sensors etc..... sure it has got to be electrical/ecu based.........
p.s. New Cambelt, Water Pump etc.. at 57k (58k now)
New Mot 1/4/2010 passed Emission with ease?
No burning smells, cooling liquid brownish in colour but smells of antifreeze, no oil filler slugging, all engine electrics clean and connected?
« Reply #7 on: 03 May 2010, 20:59:34 »
What are the *current* symptoms.
Jezzer
  • Herts
« Reply #8 on: 03 May 2010, 21:48:18 »
Sorry mate misunderstood what you meant.
The Autobox is stuck in 'safe mode' i.e. you have to shift it manually, Gear 1 to pull away then up through gears and back.
All gears are selectable, no clonking or roughness with changing.
There are no LEDs on the Selector (PRND123) to right of selector.........
No Kickdown
No Sport Mode
No Winter Button
Info Panel says 'Automatic Gearbox' when starting up.
ALL other Electrics on car are fine.
Engine runs very well?
« Reply #9 on: 03 May 2010, 22:33:56 »
Right.
Turn ign on (not starting).
Do you get Autogearbox warning then?  Do the LEDs light up 1,2,3,D,N,R,P as appropriate.
If you get the warning, and LEDs dont light up, change the selector switch ;)
Jezzer
  • Herts
« Reply #10 on: 04 May 2010, 09:09:55 »
Hi The Boy
Thanks for the reply and your patience  ;)
Will check later but sure the waring only comes on after. engine started, and LED's on selector don't come on at all.
 :o
Jezzer
  • Herts
« Reply #11 on: 04 May 2010, 14:39:55 »
Hi
Tested:
The 'Autobox Warning' does not come on until after starting the engine AND Selecting a gear (forward or reverse) Does not come on at all before then?
Stays on for 5 secs or after pulling away.
LED's do not come at any time?
« Reply #12 on: 04 May 2010, 19:02:29 »
Chage the selector.
Jezzer
  • Herts
« Reply #13 on: 05 May 2010, 14:23:48 »
Hi 'TheBoy'
Spot on advice my friend!
Took car into 'The Car Works' in Berkhamsted today put it on Tech2 and found a wiring problem to the Selector, repaired and now running fine!
Many Thanks
