Author Topic: mv6 2.6 smokin  (Read 1619 times)
frankee
mv6 2.6 smokin
« on: 05 May 2010, 19:37:53 »
when left over night or all day at work on start up there is a cloud of blue smoke and then no more after that even thrashing thro gears there is no smoke.on tick over it is very slow to pick up on throttle,like a second or so.
Re: mv6 2.6 smokin
« Reply #1 on: 05 May 2010, 19:45:19 »
Stem seals, I bet its a 2001ish model......there was a faulty batch
frankee
Re: mv6 2.6 smokin
« Reply #2 on: 05 May 2010, 19:54:26 »
correct it is 2001  on a y plate i have only had it for 5 weeks and think it is a smashing car,but i know with 120,000 on clock it needs some tummie lovin care
Re: mv6 2.6 smokin
« Reply #3 on: 05 May 2010, 19:56:52 »
You have two options
1) Rip the heads off and change the stem seals
2) Ignore it and just keep an eye on the oil level
Smooth
  • N.Ireland
Re: mv6 2.6 smokin
« Reply #4 on: 05 May 2010, 20:41:54 »
I have the same car dude and mine was doing the same,i cleaned the breathers which were clogged up like a 60 aday smokers lungs and this cured the problem,worth a try first :y
If Jesus had a licence he would drive an MV6
frankee
Re: mv6 2.6 smokin
« Reply #5 on: 06 May 2010, 10:34:50 »
thanks for that,is that the four pipes going into black box on top of head?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: mv6 2.6 smokin
« Reply #6 on: 06 May 2010, 10:44:07 »
have a look here,step by step guide   http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
other rides
frankee
Re: mv6 2.6 smokin
« Reply #7 on: 06 May 2010, 10:51:51 »
thanks for that,i will do that at weekend
henryd
  • west cornwall
Re: mv6 2.6 smokin
« Reply #8 on: 06 May 2010, 10:58:35 »
just be carefull with the plastic part on top of the plenum,it can get brittle with age and heat :y
other rides
Squatch
  • Belfast
Re: mv6 2.6 smokin
« Reply #9 on: 06 May 2010, 11:11:05 »
2001 model - definately stem seals IMO. Will not affect engine power but smoke is annoying!
