Author Topic: 4 breathers plus 1 other what is it ?  (Read 875 times)
cdxv6blueomega
« on: 06 May 2010, 19:13:12 »
My friendly mechanic has started the process of taking the V6 rocker gaskets off because the oil was leaking into the plug wells. Well known problem apparently. However when he took the breathers off he also found a fifth pipe coming from the bulkhead along with the four breathers. It wasnt connected to anything so does anyone know where it should fit ?
The car is a 1999 VAUXHALL OMEGA CDX 2.5 V6 AUTO
Thanks in advance
Welung666
Re: 4 breathers plus 1 other what is it ?
« Reply #1 on: 06 May 2010, 19:14:14 »
Shouldn't fit anywhere, it's the autobox breather and is normally clipped up under the skuttle and left open to atmosphere :y
« Last Edit: 06 May 2010, 19:14:41 by Welung666 »
Abiton
« Reply #2 on: 06 May 2010, 19:19:05 »
If it's not too late, you should read and print out the following for your friendly mechanic, taking note of the requirement for genuine GM gaskets and the black sealant in the specified places:
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
Also, there's a link in there for cleaning out the breathers. This should also be followed, or the problem will recur soon.
cdxv6blueomega
« Reply #3 on: 06 May 2010, 19:27:09 »
Blimey not only are you welung but speedy too ;)
Thanks very much to both you and Abiton. I'll print out the threads and get them to him first thing tomorrow
« Last Edit: 06 May 2010, 19:39:23 by cdxv6blueomega »
Welung666
« Reply #4 on: 06 May 2010, 20:24:17 »
You must be psychic! That's my CB handle ;D
Page created in 0.01 seconds with 14 queries.
