Author Topic: spongy brake pedal  (Read 1806 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
spongy brake pedal
« on: 05 May 2010, 15:17:17 »
hi all i have just changed the front diskes and pads on my car ( going to do rears at weekend inc hand brake shoes ) but now the pedal feels as if it has a lot of travle the car stops ok but something doesnt feel right any ideas also it pulls slightly to the left ?
2001 MV6 3.2 manual been converted from 2.6 auto
Re: spongy brake pedal
« Reply #1 on: 05 May 2010, 15:51:56 »
Did you just squeeze the pistons in or did you do the sensible thing and open the bled nipple?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 05 May 2010, 20:33:20 »
if you don't know when the fluid was last changed I would start there
other rides
bigtow
  • rochester kent
« Reply #3 on: 06 May 2010, 00:48:16 »
Ahhhhh well I didn't know about the bleed nipple trick untill after I had used a king big screw driver to ease the pistons back . I will enquire about getting the fluid changed after I have done the rear disks and pads .
MickAP
  • South Derbyshire
« Reply #4 on: 06 May 2010, 19:56:26 »
I would be having a look at the rear pads/calipers first.
I was complaining about spongy brakes until it was pointed out to me about checking the rears first.
It turned out the rear pads had seized in and were just not working, hence they had a spongy feeling.
All sorted now and passed MOT last week :y.
Mick ;)
bigtow
  • rochester kent
« Reply #5 on: 06 May 2010, 23:15:57 »
I have read about the master cylnder seals reversing . If I have done this is ther a fix for it ?
tidla
  • solihull
« Reply #6 on: 06 May 2010, 23:25:24 »
pads and discs still need bedding in a bit and can feel spongy with low performance especially if the grease coating has not beeen wiped off..
customers cars with new brakes are always driven round the block to "warm them up" and bed them in.
if your confident this isnt the case then other options as mentioned need to be looked at.
bigtow
  • rochester kent
« Reply #7 on: 07 May 2010, 00:04:06 »
I gave the disks a good clean with brake cleaner but didn't think about pads
