Author Topic: control indicator light on auto box causing proble  (Read 5107 times)
hotel21
  • The Kingdom of Fife
Re: control indicator light on auto box causing proble
« Reply #15 on: 16 March 2010, 21:41:11 »
Cheers peeps.  Codes cleared and hopefully, not to return.  If (and when?) they do, they will be fresh and we can take it from there.  ;)
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #16 on: 17 March 2010, 08:21:00 »
thanks to all hope not torque convertor will keep a eye on thanks again
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #17 on: 17 March 2010, 10:05:59 »
morning all, the saga continues  car done it again driving along light came on car lost power went in to limp mode only had 3rd gear got home and now cheezed off. if it is code p703 torque convertor does anyone know roughly how much to rectify this problem?
many thanks :(
just to add the only other strange thing as if i needed more is that it aslo says on computer screen check brake lights ,but they seem fine.
« Last Edit: 17 March 2010, 12:49:32 by brian36 »
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #18 on: 17 March 2010, 19:39:32 »
hi all!
just a update:
as you seen i again had probs today, this evening had codes checked by hotel21 and codes shown were P1700 AND P0730.
can i ask the experts amongst you to help me in my endevour to have a omega to drive with pleasure.
since i only got car 36 hours ago im a bit put off by them.
many thanks for you help. :(
« Reply #19 on: 17 March 2010, 20:04:29 »
P1700 - rich or lean exhaust
P0730 - Incorrect gear ratio
The latter is often a sign of a buggered thrust washer in the gearbox.....but ensure the oil level is correct.
P1700 can be raised by a few things.....MAF reading at idle would be useful.....also make sure the breathers and throttle body are spotlessly clean
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #20 on: 17 March 2010, 20:13:00 »
many thanks for that will try find someone to do that as my mechanical skills could be written on postage stamp do you know any members in fife that can take on this task? thanks again
bri cox
  • york
« Reply #21 on: 17 March 2010, 22:15:57 »
change  your atf fluid if its done  more then 60000 or been driven harshley or used as a tow vehicle the  fluid will be dying and could be contaminated best way to clean  auto box is to flush 25 liters of dexron 3 through it and top up to correct amount
hotel21
« Reply #22 on: 17 March 2010, 22:50:08 »
Big Bri is away with best part of a gallon of Fuchs ATF and my Aldi special pump sprayer to ensure the level is tip top.  Will have a recheck of whats what after we know the fluid level is spot on.....   ;)
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #23 on: 19 March 2010, 13:02:22 »
will my omega live or die ?
atf oil changed today thought better go to garage to get it done with the fluid from hotel21, but after leaving the garage got about 1/4 mile and away it goes again. boy am i cheezed off, now after speaking to vauxhall they recomend me going to tayside transmissions in dundee. i called guy seemed ok think its definetly to do with fluid level, but i cant seem to get the right people to do it the right way, tayside trans can't get into late next week. is there any vauxhall mechanics out there around fife that can fill the autobox the correct way as described ?
if there is please give me a shout many thanks and have a good day!
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #24 on: 24 March 2010, 15:47:34 »
the saga continues, the car back from tayside transmissions today fault code p0730 still showing and car does run slightly better but still has problem, transmission ghear ratio problem . any ideas where to go now ?
many thanks :(
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #25 on: 24 March 2010, 18:30:14 »
A number of us trying to get to bottom of this one - it may be to do with whatever component/circuit sends the engine speed data to the gearbox - see link below - do not know of differences between 3.2 and other models on this.
http://www.omegaowners.com/forum/YaBB.pl?num=1269166020
mkaminski100
  • Basingstoke
« Reply #26 on: 08 May 2010, 21:28:38 »
I was going through the same problem. Friends 2.2, same fault codes. Every mechanic different opinion.
P0730 - lean mixture. First, he was told that it should be a MAF. It wasn't. Then he was told that it's a lambda...guess? Yes, it wasn't a lambda. My first guess was that there must be additional air getting through after the MAF. I have cleaned the throttle body. Small breather was completely blocked, so this stopped an oil leak from the rocker cover. Engine was running smoother, but still not right. And there was this whistling sound (air leak?), so I decided to remove the intake manifold. After removal it was found that two o-rings on injectors were missing!! This solved that problem.
P0370 (+P0748 Pressure Control Solenoid Electrical) - first we though it was caused by the engine fault but it wasn't. I got two solenoids (main pressure and TC lockup) but during removal of the small sump we have found remains of the thrust washer... :( This means his autobox has to be dropped and repaired/replaced. Do you know anyone located south who's got a facility to do it? He wants to pay for it.
Page created in 0.03 seconds with 16 queries.
