Author Topic: removing bose shelf  (Read 1069 times)
removing bose shelf
« on: 08 May 2010, 17:46:16 »
undone all visible clips on seat edge, both pillar covers removed, all pegs poked through from undernieith except the 3 on the boot edge that just pop back out again, no blind on mine as i'm fitting a shelf with blind fitted, what am i missing?
Ta.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: removing bose shelf
« Reply #1 on: 08 May 2010, 18:11:01 »
i had the same prob last week, i did the same as you, the damn thing wouldnt budge, found the front corners fouling on the seat belts, gave it a good shove upwards at the same time sort of bending it up in the middle. hth. :y
« Reply #2 on: 08 May 2010, 19:37:01 »
..... what am i missing?
Ta.
Mine was held in place by a bit of stray window glue.
    • 530D M Sport, 330i Coupe
« Reply #3 on: 08 May 2010, 20:04:02 »
Mine got stuck on the seatbelts / trim.
« Reply #4 on: 08 May 2010, 21:21:44 »
Ta.
Gold star to Bee. Nearly ended up in the front seats when it finaly let go. Glued all the way round.
I notice it has little wheels on the end of the blind, should these sit on the window? mine has a gap just enough to tap on the window over bumps.
« Reply #5 on: 08 May 2010, 21:24:44 »
Never noticed the three wheels but do make sure the three bolts are done up nice and tight as all the strength to support the blind is there.  :y
« Reply #6 on: 08 May 2010, 21:29:59 »
yeah they are tight, but i didnt get the original nuts, so had to find some, maybe i need bigger washers, or the correct nuts.......
« Reply #7 on: 08 May 2010, 21:33:47 »
Nylock nuts with captive washers IIRC.
« Reply #8 on: 08 May 2010, 21:34:09 »
Gold star to Bee. Nearly ended up in the front seats when it finaly let go. Glued all the way round. ...
I thank you kind Sir!  ;)  ;)  :y  :y
« Last Edit: 08 May 2010, 21:34:34 by Andy_B »
The Red Baron
« Reply #9 on: 08 May 2010, 23:11:12 »
Ta.
me too. :D
