Author Topic: rocker gaskets  (Read 913 times)
nmp
  • burntwood, staffordshire
rocker gaskets
« on: 09 May 2010, 14:25:37 »
Having been smelling oil when engine is warm i was told to check plug leads.So i pulled off the front left lead and it was covered in oil.Does this mean the rocker gaskets need changing and if so how much should it cost to get done or how hard is it to do myself?
Re: rocker gaskets
« Reply #1 on: 09 May 2010, 14:50:18 »
yes but the cause is blocked breathers, although they do go hard with age, use genuine vx gaskits and o rings only or they will fail early, £70 should cover it plus labour.
may need new leads as well. Dont use genuine leads though, they are extortionate i believe.
nmp
Re: rocker gaskets
« Reply #2 on: 09 May 2010, 14:57:58 »
Where are the breathers?
Hannah Judes Dad
    • the misses round the bend
Re: rocker gaskets
« Reply #3 on: 09 May 2010, 15:25:01 »
nmp
Re: rocker gaskets
« Reply #4 on: 09 May 2010, 15:37:46 »
Have you got a link to doing the rocker gaskets?
Hannah Judes Dad
Re: rocker gaskets
« Reply #5 on: 09 May 2010, 15:39:51 »
