Author Topic: Overheating problem - reason found  (Read 1356 times)
I_want_an_Omega
« on: 09 May 2010, 13:19:53 »
Hi all,
I've got to the bottom of why my "new" Elite was overheating.
The impeller on the waterpump had come off the shaft, so basically it wasn't turning  :y
A real sense of achievement I can tell you. Aux belt tensioner was also knackered - so that will be sorted on re-assembly.
That cambelt DVD came in really handy I can tell you. :y
Thanks guys ............ Rob
Re: Overheating problem - reason found
« Reply #1 on: 09 May 2010, 16:33:08 »
The impeller on the waterpump had come off the shaft, so basically it wasn't turning  :y .......
How did you find that then?  :-?
« Reply #2 on: 09 May 2010, 17:09:07 »
Op took water pump out :y
I_want_an_Omega
« Reply #3 on: 09 May 2010, 18:02:02 »
Yep - I'm all mucky now  :-/
« Reply #4 on: 09 May 2010, 18:27:08 »
Good for you! ;) It's a great feeling to fix it yourself & deny the 'stealers' a slice of your hard earned isnt it?  ;D :y
I_want_an_Omega
« Reply #5 on: 09 May 2010, 18:54:14 »
Yes, but the list of other things that need doing to her keeps growing ......
Let get the lump finished first though  ::)
« Reply #6 on: 09 May 2010, 20:16:30 »
 :y but it wouldn't be the 1st thing you thought of though   ;)
Welung666
« Reply #7 on: 09 May 2010, 20:25:52 »
I'm pretty sure I may have suggested it in a previous post. I've seen it happen twice in all the years I've had greasy hands. Very rare but often springs to my mind with over heating problems shortly after thinking are there any fins left on the impeller ;D
I_want_an_Omega
« Reply #8 on: 09 May 2010, 21:13:04 »
The impeller was 100% intact and in good condition - it was made of Brass actually.
It had simply worked loose on the shaft - so as the shaft was rotated the slightest of resistance made it stop .......
