Author Topic: head gaskit  (Read 4435 times)
paul_g
  • derby
head gaskit
« on: 09 April 2010, 21:20:35 »
hi all just got a 2.2 02 plate pre owner says hg has gone water coming out of exhaust is this true that hg has gone or could the block be cracked m8 looking at it soon any help would be app thanks
Re: head gaskit
« Reply #1 on: 11 April 2010, 06:31:02 »
bumped for replys from page 2
water out the exhaust is not unusual in itself, esp if alot of short journeys.
Any other symptoms?
paul_g
  • derby
Re: head gaskit
« Reply #2 on: 11 April 2010, 16:25:11 »
just a bit rough  running - head gaskit has gone been to see a garrage but exhaust light is on all time will this go out when head is done
Agemo
  • Cleethorpes
  • Insignia
Re: head gaskit
« Reply #3 on: 11 April 2010, 16:58:10 »
« Last Edit: 11 April 2010, 16:59:44 by Agemo »
Re: head gaskit
« Reply #4 on: 11 April 2010, 17:10:57 »
He means the EML ;)
Are you losing coolant? is there any oil in the coolant, or coolant in the oil?, any smell of exhaust gas or petrol in the expansion bottle? Have you checked the HBV? Have a look through the Maintenance Section and aquaint yourself with the relevant parts. :y
Re: head gaskit
« Reply #5 on: 11 April 2010, 17:10:58 »
does it loose coolant?
There is no such thing as 'exhaust' light, can you describe what it looks like?
paul_g
  • derby
Re: head gaskit
« Reply #6 on: 11 April 2010, 17:42:11 »
it looks like an engen says in hand book exhaust emmissions are wrong
paul_g
  • derby
Re: head gaskit
« Reply #7 on: 11 April 2010, 17:43:59 »
loosing water and water in oil header tank pressrisers
Re: head gaskit
« Reply #8 on: 11 April 2010, 18:43:16 »
It certainly does sound like the H/G has gone then! :(
On the plus side, there is plenty of room to work on the 2.2 & the job of replacing the H/G is pretty straightforward if you have a decent set of tools and are mechanically minded. A couple of members have done their own (including myself) and the general consensus is it should cost around £150 to DIY  :y
paul_g
  • derby
Re: head gaskit
« Reply #9 on: 11 April 2010, 19:05:10 »
thanks for your help looking to do it in a few weeks
paul_g
  • derby
Re: head gaskit
« Reply #10 on: 13 April 2010, 23:27:09 »
then need to get the eml light out
Re: head gaskit
« Reply #11 on: 13 April 2010, 23:28:39 »
EML light will extinguish when all faults are corrected .. :)
paul_g
  • derby
Re: head gaskit
« Reply #12 on: 16 April 2010, 23:06:34 »
thanks for the help . got all the parts now just waiting for frend to help do the repair .
paul_g
  • derby
Re: head gaskit
« Reply #13 on: 20 April 2010, 18:35:56 »
weather permiting doing the job this weekend .
Re: head gaskit
« Reply #14 on: 20 April 2010, 18:38:29 »
Good luck with it :y
