Author Topic: Exhaust Rattle  (Read 1544 times)
Exhaust Rattle
« on: 12 May 2010, 16:49:02 »
Ever since I fitted replacement flexi cat section back onto father tuns 2.2, its had a rattle from cold, it goes away with just a feather on the throttle, and its fine once warm. I've checked and i can't see it touching heat shields, if i just poke one of the centre sections with an extension bar it goes as well  :-/
Comparing it with my 2.2, the exhaust bolts go from the passenger side to drivers, with nuts being on that side. I had it other way around on father T's so tried this afternoon switching it around, but got a problem.
These are the bolts i got from the Vx Dealer:
But as you can see the thread ends 90% way up, bolting it on, does not give enough thread other side for the nut  :-/
If i go the other way, because of the exhaust pipe, the bolts cannot sit right.
Think i need longer M8's?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Exhaust Rattle
« Reply #1 on: 12 May 2010, 17:09:53 »
Shouldn't those bolts go in from the other side and into the threads on the pipe you have them screwed through without the need for nuts on the end? That's how the downpipe to exhaust setup is on the v6.
TuBy's new whipping boy.
Re: Exhaust Rattle
« Reply #2 on: 12 May 2010, 17:12:33 »
Yep.. I would have thought so
Re: Exhaust Rattle
« Reply #3 on: 12 May 2010, 17:16:52 »
Thats how i had it setup before  :-/
For some reason my 2.2 it goes the other way  :-/
Re: Exhaust Rattle
« Reply #4 on: 12 May 2010, 17:19:41 »
also mine is nut and bolted  :-/
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Exhaust Rattle
« Reply #5 on: 12 May 2010, 17:22:38 »
Someone has snapped the bolts in the past and drilled the threaded holes out and replaced with a nut and bolt.
Both cats on mine are the same, makes life easier if you have to split the joint in the future.
Re: Exhaust Rattle
« Reply #6 on: 12 May 2010, 17:24:55 »
I'll put some fresh exhaust putty on and reseal it doing it that way then  :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Exhaust Rattle
« Reply #7 on: 12 May 2010, 17:28:22 »
Good stuff Student, I'm sure no one will tell TB about your little gaffe. ;D ;D
Re: Exhaust Rattle
« Reply #8 on: 12 May 2010, 17:52:09 »
You going to pm him or me? :D :D :D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Exhaust Rattle
« Reply #9 on: 12 May 2010, 17:58:20 »
Now now LD that would be cruel to the poor lad and besides TB often looses PMs so maybe a text would work better. ;)
Re: Exhaust Rattle
« Reply #10 on: 12 May 2010, 18:08:56 »
Its all back together now and runs fine  8-)
Its exactly how it was before  :-/ - But guess it was not sat right last time.
Cheers all  :y
