Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 42   Go Down
Author Topic: Engine noise, terminal?  (Read 117717 times)
Re: Engine noise, terminal?
« Reply #135 on: 05 March 2010, 09:40:38 »
would a known working V6 injection manifold help? Thinking one off the 3.0 could rule out anything done to yours?
There is a spare manifold here. I have a good feeling about that theory. It stacks up quite nicely with all the symptoms.
I'm holding my breath and crossing everything, ready for next update.
Sure a few others following this saga are sat on the edge of their seats as well ;D
Your not rather kiddin! Been kackin it all week. Finally get the call to repay some of the help you've given me over the years, and this happens. I cant believe it.
Cant imagine your two faces on start up. Unless Mr Wood is on a wind up? i reckon he's wired a set of comedy teeth to the alternater...if only.
By the way i never opened the packaging on that manifold when Ld sent it to me for my install, never even touched it. Was glad to have it as a back up though.
That's it... You pass the buck on to me :o :o :D :D :D
I'm surprised there wasn't another update to this late last night/this morning
« Reply #136 on: 05 March 2010, 10:09:48 »
Had already arranged for 2woody to come over and chat about Megasquirt fuel injection systems. He has kindly brought some ignition leads and a couple of coil packs just in case. :y
While talking to him I had an epiphany and realised that all this messing around with Omegas is a waste of time and that the answer has a Holden badge on the bonnet. :-* Or perhaps "Turbo R" on the boot. Not sure. :-/
I will be swapping the manifolds over tonight, if all goes well. :y
nell77
  • manchester
« Reply #137 on: 05 March 2010, 10:54:44 »
Any more info sounds like the one i`ve just bought for parts
« Reply #138 on: 05 March 2010, 10:57:00 »
Glad you managed to chat something other than the Omega :y :y
Are you thinking of a problem with LPG injector location or something? Still think you're on to something with the FPR Noise :-/ :-/
« Reply #139 on: 05 March 2010, 11:18:14 »
No. Can't see the LPG nozzles affecting things, unless one has broken off! Just have an unmodified manifold complete with injectors, FPR, etc. so might as well slap it on an eliminate the final part of the LPG work, as well as the FPR.
« Reply #140 on: 05 March 2010, 11:20:20 »
Ahh... That makes sense :y :y Probably just as easy as swapping the FPR on its own ;) ;)
« Reply #141 on: 05 March 2010, 11:20:24 »
If its the ones I brought over, I can make no guarantees there aren't full of crud.  They have been stacked on shelf in garage since I swipped them from Pink about a year ago  :-[
« Reply #142 on: 05 March 2010, 11:56:43 »
OK. I'll have a look before I fit them.
« Reply #143 on: 05 March 2010, 20:23:40 »
Manifold and injectors swapped No change. :(
Plugs and leads next, I suppose. :-/
« Reply #144 on: 05 March 2010, 20:46:26 »
completely ruled out anything cambelt related? If the sound is not there during cranking  :-/ If its something in the bores should it not be there on crank?
First description sounded very much like tensioner failing on mine, worth taking the over off just to be sure?  :-/
« Reply #145 on: 05 March 2010, 21:02:25 »
has the ecu/loom been touched? petrol i mean.
« Last Edit: 05 March 2010, 21:03:13 by chrisgixer »
« Reply #146 on: 05 March 2010, 21:54:40 »
Hmmm, could we be looking at engine damage due to borewash - I'd be surprised given that its only run briefly, and at idle.
Is this the end  :'( ?
« Reply #147 on: 05 March 2010, 21:59:25 »
Not till the fat lady sings... get the head off if yo run out of options, for a look..
« Reply #148 on: 05 March 2010, 22:01:01 »
Nope.  Time is against us, that is not an option.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #149 on: 05 March 2010, 22:02:31 »
The Stoke Heaven could be its resting place....... :(
Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 42   Go Up
