Author Topic: x25dt wont rev above 1388  (Read 1793 times)
rallyraiduk
  • cheshire
« on: 10 February 2010, 23:08:06 »
anyone have an idea why my x25dt engine only revs to 1388 rpm?
tried more and less fuel pressure but nothing changes  :'(
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: x25dt wont rev above 1388
« Reply #1 on: 11 February 2010, 07:44:56 »
what yar is it? any mods done to engine?
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 11 February 2010, 09:12:07 »
Do you have an EML light on?
Get the codes read.
rallyraiduk
  • cheshire
« Reply #3 on: 11 February 2010, 10:16:40 »
no mil light on
no codes
sounds healthy when running
« Reply #4 on: 11 February 2010, 10:18:26 »
Check all the intake ducting and pay particular attention to where it joins onto the turbo.
Welung666
« Reply #5 on: 11 February 2010, 10:55:11 »
Mine was like that when the MAF went. Try unplugging the MAF and see what it does then.
« Reply #6 on: 11 February 2010, 12:23:29 »
That would have been my next step after confiming the intake is all ok.
I have seen a few where the pipe to the turbo has come off....not easy to spot with it being so low down.
rallyraiduk
  • cheshire
« Reply #7 on: 11 February 2010, 12:26:00 »
all pipes are good !!
just a thought.....its got a range rover throttle position sensor on the accelarator pedal....the same as omega????
charlie
  • sunderland
« Reply #8 on: 11 February 2010, 17:07:26 »
mine was the same as welungs unplugging the maf sorted it out :y :y
« Reply #9 on: 11 February 2010, 18:37:12 »
if x25dt and not u25dt, unplug maf as suggested!  Quick and easy test :y
If thats doesn't help, check wastegate not stuck open
rallyraiduk
  • cheshire
« Reply #10 on: 14 May 2010, 20:50:05 »
Anyone got good eprom dumps? The ecu was reprogrammed to remove the immobiliser and maybe they corrupted one of them.
« Reply #11 on: 15 May 2010, 09:56:41 »
Does it rev fairly freely in Neutral?  Is EML on?
