Author Topic: Auto Fluid & Safe Mode?  (Read 995 times)
Jezzer
  • Herts
« on: 15 May 2010, 12:36:56 »
Still having issues with my Autobox stuck in safe mode, have tried cleaning all the connecting cables, removed cleaned and re-aligned selector - re-set ECU - short of changing the lever selector switch on the gearbox (which I will do if all else fails) - I'm not sure what to do?
Since cleaning cables and connectors, it works OK for the first few minutes - then goes back to 'safe' better than before as it didn't work at all  :o
I have checked transmission fluid as VX prescribe, i.e. warm... and when I remove the plug bolt oil gushes out??? seems like its over filled  :-? they say that the ATF should be just below the level of the plug?
Could too much oil be a problem also?
RobG
    • 16 plate Mokka. Vivaro
Re: Auto Fluid & Safe Mode?
« Reply #1 on: 15 May 2010, 12:44:53 »
With the engine running :question
tidla
  • solihull
« Reply #2 on: 15 May 2010, 12:46:55 »
did you check the selector electrical tracks for corrosion and small breaks.. easily missed on first inspection, easy fix with maplins silver pen track repair. ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 15 May 2010, 13:03:10 »
atf should be checked with engine warm after a run and running,cycle gears then put it in park and check oil without switching off
other rides
Jezzer
  • Herts
« Reply #4 on: 15 May 2010, 14:05:54 »
Yep engine running... level ok...... but did need topping up a bit?
At least it works a normal for a few minutes before going back to safe mode, some improvement!
Will try the electrical connectors next... then a new or recon switch  >:(
Cheers guys!
