Author Topic: 06 2000 CDX Facelift Saloon - Drivers Door Speaker  (Read 2016 times)
Tangerine
    • 6-2000 2.5TD Auto CDX
« on: 15 May 2010, 19:54:21 »
I am having a problem with the speaker in the drivers door, in that it keeps cutting out, then back in again, so it seems like a faulty connection.
Could someone advise me please how to remove the door panel so that I can access the speaker.
Thanks
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: 06 2000 CDX Facelift Saloon - Drivers Door Speaker
« Reply #1 on: 15 May 2010, 20:06:34 »
Trade club card holder
Code scanner available
Tangerine
« Reply #2 on: 15 May 2010, 20:13:55 »
alexandjen
Thank you. I had searched under, door panel not door card!
Regards
alexandjen
  • The Silver Surfer
« Reply #3 on: 15 May 2010, 20:18:40 »
alexandjen
Regards
No problem, lots of very usefull info in the maintainance guide section and very easy to find thanks to Jimbob  :y
Tangerine
« Reply #4 on: 15 May 2010, 22:34:17 »
I have just read the article from the link above and it seems that the tweeter just levers out.  It is covered in the first line, before the door panel has been removed.  According to that then, the panel can stay in place!
alexandjen
  • The Silver Surfer
« Reply #5 on: 15 May 2010, 22:38:10 »
The tweeter is the small treble speaker at the top of the door card, the main speaker is behind the door card at the bottom nearest the hinge - I'm sure there was a guide on here with step by step photos, or did I dream it  ::) :-/
Tangerine
« Reply #6 on: 15 May 2010, 22:44:05 »
I'm not sure which is causing the problem but hopefully it is just the Tweeter.
Thanks
  • Auckland
    • Mazda MPV
« Reply #7 on: 15 May 2010, 23:23:21 »
I spent this afternoon changing all my door speakers. If you had posted your question earlier I could have taken photos while I was doing it
It took me a little while to find all the fixings but the facelift Omega must have one of the easiest door cards to remove (undamaged) of any car I have owned :)
1. the little plastic grille in front of the door handle (and hides the tweeter) - pop it off. I used my fingers but you might need to use a screwdriver.
2. finger plate behind the doorhandle (includes the tweeter mounting). There are two plastic prongs on the back of it (behind the tweeter) that clip into the door card. I used a screwdriver to ease the top one out and then the bottom one unclipped fairly easily. Pull the door handle half open and the fingerplate should come away from the doorcard. Once the fingerplate is off you can undo the Philips screw that is hidden behind it.
3. armrest fixing screw. Open the storage bin in the armrest and unclip the lozenge shaped plastic cover (it's the bit that your fingernails scratch when you press the button to open the storage bin). Unscrew the Philips screw hidden behind it.
4. Philips screws. There are 7 or 8 screws around the edge of the door card. All are easy to see (two of them might be behind plastic caps at the front of the door if the caps haven't already fallen out)
The top of the door card clips onto the bottom edge of the window opening. The first doorcard I removed completely but I didn't bother with the other 3, I just held the card up enough to get to the speaker.
WARNING
I think the front doors have impact sensors inside the doors to trigger the air bags. If you only touch the speakers and speaker wiring it won't affect the impact sensors. If you discover chaffed wires at the door hinges then be careful not to disconnect any wires that you cannot identify.
If you do disconnect any air bag wiring and switch the ignition on then you will need to get the airbag warning lamp reset afterwards as it won't go out on its own.
Tangerine
« Reply #8 on: 15 May 2010, 23:35:37 »
I would like to thank you for taking the time to prepare such a detailed response.  I am looking forward to putting it to the test!
  • Auckland
    • Mazda MPV
« Reply #9 on: 15 May 2010, 23:50:47 »
No need to thank me. If I don't write it down I won't remember it for next time ::)
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #10 on: 16 May 2010, 00:54:10 »
been there - done that (normally end up with screws left over)  :'(
