Author Topic: run out of petrol- now wont start  (Read 1138 times)
degs1956
« on: 16 May 2010, 15:55:02 »
I foolishly run out of petrol in my 2.5 V6 omega, put £10 in but car wont start ! How do I bleed the petrol?   Thanx in advance.  DEREK
OmegaGav
  • Hemel Hempstead
  • For god sake doooo something !!!!!
    • 08' Vectra 3.0 V6 Cdti
Re: run out of petrol- now wont start
« Reply #1 on: 16 May 2010, 16:47:09 »
is the car on a level surface ? vauxhalls are notoriously bad when low on petrol if they are not level  :-[ :-[
you do not need to bleed petrol engines  :y
Yes it's my M&S goulash cannon. Ready Aim Fire...!!!
Pete Elite
  • Uxbridge, Middlesex
« Reply #2 on: 16 May 2010, 16:52:16 »
£10 is not a lot of petrol(less than 2 gallons)and if parked on a slope it may not be enough to be picked up so try putting some more in and make sure the car is on flat ground :y.
       HTH,
             Pete :).
Pete Elite
« Reply #3 on: 16 May 2010, 16:53:02 »
Must type quicker ;D.
OmegaGav
  • Hemel Hempstead
« Reply #4 on: 16 May 2010, 17:30:46 »
 :-X :-X ;D ;D
ballcock50
  • South Wales
« Reply #5 on: 16 May 2010, 20:52:45 »
I had this problem on one of mine a while ago could not get any power to the fuel pump. There was power out of the relay but not at the fuse so as I had to move it I jumped a supply to the fuse to start the car once started I removed the link and it stayed running never had a problem since.
