Author Topic: Steering Idler  (Read 1466 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
Steering Idler
« on: 16 May 2010, 18:13:01 »
I think my sterring idler is completly knackered now its been wondering whilst braking for a while now i have a knocking all the time when going over any bumps what is the best one to buy and where do i get one from?
Re: Steering Idler
« Reply #1 on: 16 May 2010, 18:16:57 »
Get the steering idler from here
http://cgi.ebay.co.uk/Vauxhall-Steering-Idler-Arm-110mm-9195731-Omega-Carlton-/200464525151?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eac9de75f
there are cheaper ones but they tend to be rubbish. The knocking is more than likely drop links but they are quite cheap and easy to do.
downsmen
  • Kent
Re: Steering Idler
« Reply #2 on: 16 May 2010, 18:53:43 »
Thanks have just ordered one hopefully its not to hard to fit
MickAP
  • South Derbyshire
Re: Steering Idler
« Reply #3 on: 16 May 2010, 18:58:16 »
That's the one I fitted in Pete's link :y
A doddle to fit, but not to get the old one off.
I had to knock ten bells of shite out of if before it gave way >:( >:( >:(
Mick ;)
Re: Steering Idler
« Reply #4 on: 16 May 2010, 18:58:45 »
downsmen
  • Kent
Re: Steering Idler
« Reply #5 on: 16 May 2010, 19:04:04 »
Cheers thanks for all your help
2woody
  • Northumberland
Re: Steering Idler
« Reply #6 on: 17 May 2010, 11:49:37 »
make sure it's the same length as the old one - there are at least two different lengths - having a different steering setup on one side of the car only has not proved to be beneficial to the handling.
brett wood
Re: Steering Idler
« Reply #7 on: 17 May 2010, 12:17:53 »
I went to do mine this weekend I found it easier to prize the large rubber end downwards to free it off then wedge a socket between the steering arm and chassis and knock the idler upwards of the ball joint when I went to fit my bnew one from vauxhall parts on the web the balljoint hole had been machined to big so it slopped about on the ball joint
