Author Topic: Tinted rear clusters  (Read 1240 times)
maximoke
  • Daventry/Northampton
« on: 17 May 2010, 20:14:52 »
Hi there.  A previous owner of my car decided to tint the rear lights.  I think it has been done to the outside - from feel, and wandered if anyone knew any product I could use to remove it as I dont like it.  Cheers in advance.
Simon72
  • Wolverhampton
Re: Tinted rear clusters
« Reply #1 on: 17 May 2010, 20:43:06 »
It's hard to remove tint paint on the tail light specially the tail light are made by plastic. You can try to dip them in the WD40 for at least 2 hours and use finger nail and or credit card plastic to remove it other than that you will sratch the finish.
That is only way, do not use chemical paint remover or acetone (nail Varnish Remover) or Petrol that you will damage the light housing as well.
They are messed up anyway, try that and if it doesn't work then buy some new ones.
Good luck.
SJKOO01
« Reply #2 on: 17 May 2010, 21:37:45 »
You could always try this type of cleaner / remover ?.
http://www.demon-tweeks.co.uk/Product/Performance/Lighting/Lens_Tinting/Foliatec_Stoplight_Spray/860/3123/37230
Or find someone who want's to swap their clear ones, for your tinted ones ?.
« Last Edit: 17 May 2010, 21:39:06 by SJKOO01 »
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #3 on: 17 May 2010, 21:56:37 »
I have a set off a mini face lift saloon if they will fit yours . If you put your location on your profile it will help us know who is the nearest to you to help you
2001 MV6 3.2 manual been converted from 2.6 auto
« Reply #4 on: 17 May 2010, 21:57:49 »
I would think that as these lights have been tinted, they are facelift lights. Prefacelift cars already have tinted lights  :y  :y
bigtow
  • rochester kent
« Reply #5 on: 17 May 2010, 22:01:14 »
Did they do a 2.5 facelift ?  I didn't know that ?
« Reply #6 on: 17 May 2010, 22:02:54 »
they did, then they upped it to 2.6  :y, same as 3.0 facelift was later replaced by the 3.2   :y
« Reply #7 on: 18 May 2010, 08:58:36 »
Go to somewhere like "Toolstation" or a UPVC window supplier and get some "Solvent cleaner". Should remove the tint and won`t damage the lens
Page created in 0.025 seconds with 16 queries.
