Author Topic: fault code 19 incorrect rev sigal on 2.5 v6  (Read 1461 times)
rhinofender
« on: 18 May 2010, 10:06:39 »
Hi, can anyone advise me on how to remedy this fault please?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: fault code 19 incorrect rev sigal on 2.5 v6
« Reply #1 on: 18 May 2010, 10:10:03 »
someone correct me if I am wrong but that code will always be present if codes are checked with engine switched off
other rides
coastie123
  • sidmouth, devon
« Reply #2 on: 18 May 2010, 10:10:09 »
Crank sensor..
I have the same fault - see my topic "some code questions"
coastie123
  • sidmouth, devon
« Reply #3 on: 18 May 2010, 10:11:16 »
code 19 is crank sensor
code 31 is usually present with the engine off..
henryd
  • west cornwall
« Reply #4 on: 18 May 2010, 10:12:24 »
I stand corrected :y ;D
other rides
« Reply #5 on: 18 May 2010, 10:18:24 »
Here you go matey http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
Suggest you replace with genuine VX before it packs up completely and leaves you stranded
rhinofender
« Reply #6 on: 18 May 2010, 13:06:51 »
Thanks very much for your help
rhinofender
« Reply #7 on: 18 May 2010, 17:23:37 »
Have managed to remove sensor and wiring, how does one test the sensor?
« Reply #8 on: 18 May 2010, 17:27:01 »
If you were getting code 19, its breaked  ;)
