Author Topic: Help needed PLZ regarding the testing of DIS pack  (Read 1152 times)
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
« on: 19 May 2010, 10:01:27 »
According to the advise of MarksDTM the following was written -
'A crude method for testing your DIS pack is to unplug the knock sensor and run the engine, the retarded timing will result in a higher voltage being required to ignite the fuel and hence a weak DIS pack will often miss fire'
Does anyone know if BOTH sensors have to be unplugged or will just one suffice  :-?
Re: Help needed PLZ regarding the testing of DIS pack
« Reply #1 on: 19 May 2010, 10:03:31 »
Mark will tell me off for this - as, you should eliminate things properly... but, For £37, I would (did) just replace the damn thing :y
eliteomegaman
« Reply #2 on: 19 May 2010, 10:22:32 »
Ahh but did it cure the problem? (as my doctor would say!)
My problem is this - i'm as much use as a chocolate fire guard when it comes to mechanics & i thought in my wisdom that it would be far easier for me to unplug something than to replace something  ::) :-[
