Author Topic: fault code 19  (Read 928 times)
rhinofender
fault code 19
« on: 19 May 2010, 17:32:43 »
Hi, members very kindly advised previously on the code, what it means and how to replace the crank sensor. Unfortunately after fitting a new one whilst battery was disconnected, the car starts better but we still have a fault code 19, is this normal? Very grateful for any advice you can give.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: fault code 19
« Reply #1 on: 19 May 2010, 17:35:24 »
code will disapear after some run cycles or you may have to use a code reader to delete it
other rides
Re: fault code 19
« Reply #2 on: 19 May 2010, 17:35:57 »
The fault code will remain logged in the ECU till it's had 20 or so 'clean starts' or cleared via a code reader. Give it a few days & do another paper clip test & I'm sure it'll have gone.  :y  :y
rhinofender
Re: fault code 19
« Reply #3 on: 19 May 2010, 19:51:04 »
Thanks very much
