Author Topic: Towbar on an estate  (Read 1460 times)
Sixstring
  • Lydney, Gloucestershire
Towbar on an estate
« on: 21 May 2010, 16:10:30 »
Is there a "how-to" on fitting a towbar on an estate?
got to do mine this weekend, anybody have any advise cos they've done one before?
All replies (apart from p*ss takes) appreciated.
Mike.
Re: Towbar on an estate
« Reply #1 on: 21 May 2010, 16:30:32 »
guessing it would be towbar manufacturer specific, afaik noones ever done one.  Be my guest if you fancy a crack  :y
Sixstring
« Reply #2 on: 21 May 2010, 16:36:06 »
Right! I will.
(if I can get the pictures to come out properly, havent really sussed how to do that, yet)
Might get Broomie to help me with publishing it........
« Reply #3 on: 21 May 2010, 16:37:50 »
if you dont / cant get photos on line, you can always email them to me, and tell me where to put them  :y
Sixstring
« Reply #4 on: 21 May 2010, 16:42:48 »
Thanks mate, can do it in word format, might send the whole article over to you if you dont mind. can i have your email addy via PM?
Mike.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #5 on: 21 May 2010, 17:26:07 »
I have just fitted a brink detachable to mine and its was easy to do,the holes in the bottom of the rear chassis legs are already there and the boot floor above is dimpled where you need to drill.I used a 7 way bypass relay on mine but not sure if its strictly neccesary( I was concerned that the bulb failure system would have a fit when the trailer was attached)
edit: too my knowledge the brink is the same as genuine vauxhall and the removeable bit fits in the space provided where the jack etc goes
« Last Edit: 21 May 2010, 17:29:49 by henryd123 »
other rides
« Reply #6 on: 21 May 2010, 17:26:25 »
just click on my name...my email is public here  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 21 May 2010, 18:44:04 »
if you have alook under the carpet each side of the spare wheel door you will see little nipples where you need to drill holes for the towbar. it pretty straight forward mate.
