Author Topic: Coolant leak/ back of the engine on my 2.6  (Read 1039 times)
mikejaytee
« on: 22 May 2010, 16:18:18 »
Hi all,
I have a coolant leak somewhere from the rear of the engine compartment on my 2.6. There is coolant loss and water is evident dripping from the rear/right side of the engine around the bellhousing. I  suspect heater hoses and/or heater valve. Has anyone else expereined this?? and if so what was the source of the leak? It is difficult to see just where the water is coming from, so I'd be grateful for any observations before I strip out the top of the engine to reach the hoses and/or valve.
Many thanks in advance...  :D
Mike.
omegadan67
  • northampton
Re: Coolant leak/ back of the engine on my 2.6
« Reply #1 on: 22 May 2010, 16:21:30 »
could be the heater by-pass valve(hbv) you dont need to strip down the top of your engine just the window wipers and scuttle panel that should enable you to change the hbv though not difficult to do it is trickey hth
A little infomation is dangerous in the wrong hands
mikejaytee
« Reply #2 on: 22 May 2010, 16:23:50 »
Hi there,
many thanks for the quick reply!!
I think you could be right...I do think it is heater valve connected.... I'll get down to it and see what I can find!
Cheers,
Mike.
bert
« Reply #3 on: 22 May 2010, 16:25:17 »
Yes had this problem last week  you will find me further down the list i changed the heater by-pass valve it made   a bit of diffrence but still was dripping ended up putting radweld plus in and has stop dripping(touch wood) if you find my query there is a lot more info good luck,just one thing if you do change the hbv the hoses are a pig to pull of i used the wifes hairdryer made it easy
« Last Edit: 22 May 2010, 16:35:24 by bert »
mikejaytee
« Reply #4 on: 22 May 2010, 17:27:26 »
Many thanks bert.
