Author Topic: Erratic Idling?  (Read 833 times)
Jezzer
  • Herts
Erratic Idling?
« on: 23 May 2010, 11:29:06 »
Only when hot the idle 'hunts' between 1,000 rpm and 2,000 rpm? am having some issues with running hot.
At normal temp all seems fine?
2.0 16v Auto 58k, new cambelt, water pump, autobox selector switch....
Any thoughts? :o
soupdragon44
  • stevenage
Re: Erratic Idling?
« Reply #1 on: 23 May 2010, 11:38:06 »
clean out the throttle body with carb cleaner and if that doesn't help take off the idle stabalisation valve and clean that out with the same, you may have to spray cleaner in it and leave to soak for a while and then drain out.....
